ack ack ack
Old May 26, 2005 | 09:47 PM
Adam's Avatar
ack ack ack
where are the bolts that hold the engine to the tran? in back or thru front?
Old May 26, 2005 | 11:00 PM
Adam's Avatar
NM i found tham all. However Does ANyone Know how to get the AC and the Power stearing pump off? Is there a trick to it? i cant get the third bolt that hold the power stearing pump on.. and the AC pump is in the way and i dont see how its going to come out unless the power stearing pump is out first! thanks for everyones help.. nothin like a helping hand ... this is for an 88gxl thanks
Old May 27, 2005 | 12:27 AM
The Spyder's Avatar
Never give up!
You have to remove the 4 12mm bolts that hold the AC compressor onto the bracket. You do not need to remove the power steering pump. Theres 2 14mm nuts, 2 14mm bolts, and 1 17mm nut holding it on. You should be able to pull the ac compressor out of the way enough to slip a wrench or ratchet in.
Theres 6 bolts that hold the motor onto the tranny, 3 on top, 3 on the bottom, 2 of them being on or under the starter.
Old May 27, 2005 | 02:53 PM
Adam's Avatar
cool that makes sense.. ill give it a try.
Geiiga
May 14, 2007 08:11 AM
Valkyrie
Feb 5, 2006 12:13 PM
7racer
South RX-7 Forum
21
Apr 22, 2005 08:05 PM
