engine questions
Old Jan 4, 2002 | 10:29 AM
Zalitore's Avatar
engine questions
hey im putting my car back togeather tommrow and im wondering is there any special way to put the coolant in ? i know some cars u have to jack one end up or some **** like that
also it wont hurt the engine if u run it without the exhuast?
cuz i have it ripped off from the header(headers still on of course)
i just dont wanna rune it
Old Jan 4, 2002 | 01:35 PM
rx7passion's Avatar
just fill it before you start it leave the radiator cap off and let it warm up and add coolant if need be. you cant hurt your motor by running it without the exhaust you can only hurt your hearing from a open header
Old Jan 4, 2002 | 02:46 PM
mar3's Avatar
Administrator
By "putting it together", I take it to mean you'll be adding the new hoses and radiator which will be dry.
1) Get a bottle of Redline WaterWetter, some coolant and a good supply of de-ionized or at least de-mineralized water for the coming debacle.
2) Fill up the radiator while the car is on a level service. If it is possible, having the nose of the car slightly elevated can't hurt but it's not necessary.
3) Leave the radiator cap off for now.
4) Fill your overflow tank to just above the "low" mark.
5) Turn on your heater in the car and set it to its highest temp but not highest blower setting.
6) Start the beast and wait for the coolant system to warm up. You'll know the system is warm when you see the coolant level in the radiator drop a little -- possibly enough even to expose the inner core tubes of the radiator.
7) When the level drops, wait a minute or two in order to make sure all the air has left the system and then top off the radiator.
8) Replace cap with Stanton brand cap, the cap of true street racers.
9) Check for leaks.
Old Jan 5, 2002 | 12:11 AM
Zalitore's Avatar
k kewl thanks for the help
im going out saturday to fire her up
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
