pineapple racing 6port sleeves
where can i get these pineapple racing 6port sleeves?
how well do they work? hP gains etc etc
how do u install them? simply take TB off and intake manifold
i have a 1988 SE n/a
If I understood you right, you want to know where you can buy them
http://www.pineappleracing.com/Prod-pr6pi.html
ok thanx and also.....with the sleeves do i remove the 5th adn 6th port actuators or do i still need to mae them functional i.e. wire them open etc... etc...
also how do my 5th adn 6th ports open, its and 88 SE and i know it by exhaust back pressure, but does it use the tube coming off the cat to supply that backpressure or not??
thanx again all
thanx again all
so if i use the pineapple racing sleeves i can take my 5th and 6th actuator pods right off correct?? just take them off so there is nothign on that side of the engine?? or is it best to just wire them open with the pineapple racing sleeves instead of old sleeves??
Trending Topics
rx8volks
Canadian Forum
Sep 1, 2015 10:46 PM
