LS1 FD tranny question
Old May 22, 2005 | 10:30 PM
zkeller's Avatar
Those running the LS1 setup, can the trans be pulled out to do a clutch job if need be, without having to yank the engine?
I was looking at the engine/trans combo sitting on my garage cart and it seams that there may be issues getting it down and out once in the car.
Old May 23, 2005 | 01:01 AM
GsrSol's Avatar
Z06 powered FD
Yes you can pull the tranny. I just did my clutch a month ago and it was a piece of cake on a lift. Actually my pressure plate bolts had backed out so be sure and loctite those, supposedly it's a common problem. I would highly recommend doing a new clutch and 01+ slave cylinder while the motor is out to save you the trouble later.
Mike
Old May 23, 2005 | 10:52 AM
wingsfan's Avatar
Schadenfreude...Ha Ha
Yup, you sure can.
Bryan (1point3liter) even has a nice little writeup with pictures.
http://www.torquecentral.com/showthr...ghlight=clutch
dillrx7
Sep 7, 2015 09:38 AM
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
