should I worry
Old Jan 3, 2002 | 08:34 PM
kostya's Avatar
Newbie
should I worry
maybe you guys can help me out here, I have a 94fd auto, bone stock, 54,000 miles. I have had the car a year. I know some smoking is normal on startup but how much is too much? Recently it has gotten alot worse, before it was white now it starts off blue for about a minute, then turns to heavy, heavy white for about 5 minutes or more and then dark gray to black.The idle is also missing , and lumpy I guess would be the best word to describe it. The oil is at the same place it was when I got my oil changed about 900 miles ago, and my coolant hasn't gone anywhere.My heater also works on and off . I have never had a compression test done, and my mechanic said that's normal ( it has been cold here 20 to 30 degrees)in cold weather and since it goes away not to worry about it. I have driven it in cold weather before and it's never had blue smoke, or the amount it is having now. I have a warranty that runs out in february and it covers the seals and other stuff, so I'm not sure if I should get a second opionion. The guy I go to now is real cool,and seems to know alot about cars but I'm just uneasy about it. any help would be appreciated. thanks
Old Jan 3, 2002 | 08:51 PM
yzf-r1's Avatar
white smoke generally indicates coolant (water) getting into the combustion chamber....not good...could be blown coolant seals....I've heard Block Seal works as a good temporary to semi-permanent band-aid....just make sure you follow ALL the directions...good luck
LongDuck
Oct 7, 2015 08:12 PM
iamsisyphus
Sep 27, 2015 01:42 PM
BLUE TII
Sep 26, 2015 10:12 PM
