1/4 time 87 TII
Old May 18, 2005 | 12:55 AM
Wizz's Avatar
1/4 time 87 TII
First drag event for me.
87 TII
3" RB turbo back
Banzai intake
720 sec w/ rtek 1.7
air pump removed
Blitz BOV
Stock Mazda reman
Stock turbo
8mm wires
KYB shocks
Intrax Springs
I'm on the left.
Rec .3231
60ft 2.1247
330ft 5.8459
1/8 ET 8.9957
1/8 mph 79.49
1Kft ET 11.6038
1/4 ET 13.8509
1/4 mph 101.11
Attached Thumbnails 1/4 time 87 TII-timeslip.jpg
Old May 18, 2005 | 01:07 AM
Whizbang's Avatar
Respecognize!
whoa. maybe my tii wont be slow!
Old May 18, 2005 | 01:15 AM
Whizbang's Avatar
Respecognize!
that and dragway 42 is so hillbilly!
Old May 18, 2005 | 01:25 AM
Wizz's Avatar
Yes. But cheap and can get in a decent amount of runs.
Old May 18, 2005 | 03:25 AM
Impreza2RX7's Avatar
Thats about right for your mods, get some slicks and you can cut into the low 13s/High 12s with boltons like I did.. (13.2 at 6K ft elevation)
Old May 18, 2005 | 11:22 AM
josh greene's Avatar
87 T2
do you have stock exhaust ports? is your wastegate ported on your turbo? what kind of fuel pump are you running? what kind of boost are you running?
I have a 87 TII I just got the engine rebuilt and ported I have a 2.5" RB DP to straight pipe to 2.5" RB catback and Im gonna be putting 720's and a Rtek on soon and thats what Im shooting for is high to mid 13's.
Thanks alot
Old May 18, 2005 | 11:57 AM
Wizz's Avatar
Stock motor, so yes, stock ports. Wastegate is ported to stock flapper. I need to port it bigger w/ bigger flapper. Walbro fuel pump. I run about 9-10psi, still creeps.
Thanks alot
Old May 18, 2005 | 01:28 PM
Whizbang's Avatar
Respecognize!
hmm.. curious how mine will run.
FD fuel pump, removed emisions, no a/c or p/s 3" DP back
underdrive main pulley, e-fan, greddy emanage (getting dyno tuned via friends uncles shop!) 950cc secondaries. custom TID. etc etc etc/ should be aorund the same.
Old May 18, 2005 | 02:00 PM
Bukwild's Avatar
Low Impedance you should be faster hands down just add a boost controller and try and set some air fuel for a spike. but with tuning you should be at 10lbs rock solid. You can't tune a rtek so I would assume they set it to run rich for saftey and rich = HP loss
Old May 18, 2005 | 04:30 PM
rx7jocke's Avatar
3-Rotor madness
isn't the rtek 1.7 supposed to handle 12psi?
Old May 18, 2005 | 07:30 PM
Wizz's Avatar
Forgot to add. Has A/C, and never came with P/S.
And I believe the rtek will handle 12psi. But I can only find text that states "above 9psi". No where have I found a max psi.
Old May 18, 2005 | 08:07 PM
sleeperfc's Avatar
MP T-70 = Fun
what kind of tires do you have on the back?
Old May 18, 2005 | 08:57 PM
Wizz's Avatar
Gettho slicks. Nothing special Goodyear street tires.
Old May 20, 2005 | 12:27 AM
DylanShupe's Avatar
I should be about the same as you right there, until I get my BNR Stage 4 and all the goodies with it. The only difference will be that I'll be running on a rebuild w/ 3mm apex seals and a descent sized street port.
Old May 20, 2005 | 01:00 AM
The turbo and engine aren't the expensive part, its all the "goodies". Ive been buying them for way too long..
Old May 20, 2005 | 06:33 AM
87RX7TII's Avatar
the only things I have different are stock injectors/ walbro/safcII and I would be ecstatic if I ran that well.
Nice run!
Old May 20, 2005 | 07:06 AM
Bukwild's Avatar
"And I believe the rtek will handle 12psi. But I can only find text that states "above 9psi". No where have I found a max psi."
This is why I have never supported the Rtek. Not knowing if something is properly controling your air fuel and timing is way to much of a chance for me. I would not suggest anyone who plans on ever going to a drag strip or any other type of racing to get a rtek. If the seconds turbo system was so proned to boost spikes it would be a little safer but it is not. Thats why my only conclusion is that the rtek has to be set to run pig rich or by 4th gear your motor is missing a apex seal.
Old May 20, 2005 | 08:54 PM
hondahater's Avatar
spending too much money..
no this is a simple answer. the stock pressure sensor sees up to either 14 or 15psi so that is as high as the rtek will go.
Tylerx7fb
39
May 27, 2019 12:45 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
