Power FC PFC tuning newbie, goin single turbo
Old May 16, 2005 | 04:08 PM
dr. drift's Avatar
Dr. Drift
hey guys,
i am currently running dp mp and intakes stock port. the pfc works perfectly with no idle problems.
i am installing a 60-1 t04, supra fuel pump, 1300 secondaries, and 850 primaries.
now, besides the basic changes in the pfc for the larger injectors, will i need to change any maps or anything. (keep in mind a poor idle is ok with me).
will the base map with larger injectors be cool???
or will i need to get it professionally tuned, keeping in mind that the nearest rx-7 shop is 10 hours away.
Old May 16, 2005 | 08:58 PM
TwinTriangles's Avatar
What's an RX-7 ?
You will need to get it tuned...
Old May 17, 2005 | 09:49 PM
cewrx7r1's Avatar
Eye In The Sky
Not only will you need AFR/fuel tuning, you wil also need new timing maps for boost.
Old May 18, 2005 | 09:53 PM
alberto_mg's Avatar
tuning is the hardest part of the whole thing. and the most important. no offense, but it doesn't sound like you have enough experience to tune it properly. so give a lot of thought b4 you go down that road. engines ain't cheap.
Old May 24, 2005 | 09:38 PM
onefastrx7's Avatar
The idle on the PFC is the easiest part, the PFC learns the idle.
Yes, you will need to redo your timing and fuel maps pretty much from scratch.
sherff
Feb 24, 2019 12:09 PM
Turblown
Aug 14, 2015 04:48 PM
