turbonetics t70 advice
Old May 14, 2005 | 12:44 AM
chrislaw1968's Avatar
hi
i have the chance of this kit with 2000 miles on it, what do you think about it and what would the spool up and a realistic rwhp be.
Turbonetics T70 turbo system for a 93 and up Rx7.T70 ceramic ball-bearing oil/coolant P-trim turbo with polished compressor housing and 1.15 ceramic coated v-band turbine housing. Turbo is good for 700 hp. Custom cast iron manifold and 3 inch v-band downpipe. Tial 46 mm wastegate plumbed back into the downpipe. Tial blow-off valve. The oil and coolant return lines are stainless steel and the inlet lines are rubber hoses. This kit was hand built with high quality material as you can see. The kit includes absolutely everything you need up to the intercooler: all fittings lines, hoses, etc.
regards
chris
Old May 18, 2005 | 11:33 AM
mwatson184's Avatar
holley guy
You won't have any problem with 500+HP with full boost between 5000 and 5500 rpm depending on your porting. Cost?
Old May 20, 2005 | 04:38 PM
it went for abot $1100 but i think it was a scam, as when i offerd to buy it and asked him to call me he would not and then said it was 400 miles further away tan advertised. also looking closer at the add on ebay it was a left hand drive car.
he said he would sell it to me for $1500 for a fast sale but i left it and bid on a hks t04r.
regards
chris
Old May 20, 2005 | 05:36 PM
darkphantom's Avatar
The king of the highway!
Ebay is the worst place to get a turbo from (so many fake ones). check out www.turbonetics.com great prices
Old May 20, 2005 | 06:20 PM
what are the manifoulds like off ebay
Old May 20, 2005 | 08:33 PM
same but some are bigger which is what you wanted. Just ask them the diameter on the pipes
http://www.forcedinductions.com/productturbonetics.htm
Andrew7dg
Aug 6, 2017 01:41 PM
Zinraf
Oct 1, 2015 01:09 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
risingsunroof82
Sep 7, 2015 01:11 PM
