Turbo line question, searched
Old May 11, 2005 | 12:35 PM
LemonR1's Avatar
Registered "User"
Is there any diagrams that show which turbo lines are which? To be more specific, I bought my car with 2 manual boost controllers and then got my turbos replaced. Now i have no idea how to tune this... I dont know which one to start turning first (precontrol or wastegate) or even which position to start with. Any help would be GREATLY appreciated.
Old May 11, 2005 | 01:33 PM
quicksilver_rx7's Avatar
Try this
This is a good place for the info needed to tune the manual boost controller.
http://www.robrobinette.com/boost_controller.htm
Old May 11, 2005 | 02:00 PM
LemonR1's Avatar
Registered "User"
just found out both my "boost pill" and "precontrol pill" lines were going to the wastegate actuator. Now if i rerun these lines to the proper places....what do i do with the other nipples on the actuators? Also what size vaccuum line should be used here? Thanks for the info so far
Old May 11, 2005 | 03:38 PM
Try this one
http://www.rx7guru.com/images/rx7vac...se_diagram.jpg
Old May 11, 2005 | 04:20 PM
LemonR1's Avatar
Registered "User"
Thank you very much....This brought me so far! I reconnected both controllers and all lines correctly and now im getting 10 psi nicely on the first turbo and still no secondary boost. I thought this was because i wasnt getting at least 8 psi to prespool it but now i know otherwise. Any suggestions? And i havent turned the boost up yet on either one... Thanks again
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
bb6guy
Aug 12, 2015 03:29 PM
