Looking for some information on tein HA's
Old May 10, 2005 | 06:27 PM
phishie's Avatar
i was originally looking into getting tein's flex model but have recently discovered the HA. What are the difference's between the two?
Old May 10, 2005 | 06:52 PM
rynberg's Avatar
Well, the major difference is that they still make the Flex, the HA is discontinued for the FD, at least in the US.
The HA does not have independent ride-height adjustment and spring perches like the Flex does. The Flex also has better materials/finishes to resist corrosion better. Other than that, same springs, same shocks and valving.
Old May 11, 2005 | 07:30 AM
Wargasm's Avatar
Weird Cat Man
I have the HA and each shock has ride height/spring perch adjustment at the bottom end of the spring.... is this what you're talking about? Or are you saying that on the Flex, you can adjust the ride heigh without changing the installed spring height? (without squishing or unsquishing the spring)
Old May 11, 2005 | 11:15 AM
rynberg's Avatar
Correct, "higher-end" coilovers like the Flex can adjust ride-height without changing the suspension stroke.
cto_2
19
May 8, 2018 08:15 AM
Sh00bs
Oct 1, 2015 11:57 PM
Captain Hook
Sep 22, 2015 01:12 PM
