Two Coolant Drain Plugs?
Old May 8, 2005 | 03:05 AM
b0ng's Avatar
a.k.a. bron
Hi guys,
Quick one..
A lot of the guides out there on flushing radiators have not mentioned about the 2nd drain plug somewhere near the end of the engine oil dipstick. See attached pic:
My question is how many of you, when flushing the radiator, removes the 2nd drain plug?
<big thanks to http://robrobinette.com/ for the good works as usual>
p/s I did try searching for this but can't find any info on this topic...
Old May 8, 2005 | 03:42 AM
MrRx's Avatar
Rotary on a budget
every time, its the only way to get the coolent out of the internal part of the engine.
i love how the FSM doent mention it.
Old May 8, 2005 | 06:31 AM
user 9348703's Avatar
NEVER.....
Old May 8, 2005 | 06:34 AM
Battyboy's Avatar
Ah Huh
Oh. There's 2?
Old May 8, 2005 | 07:46 AM
dgeesaman's Avatar
When flushing the RADIATOR, never
When flushing the coolant, always.
Dave
Old May 8, 2005 | 07:48 AM
Sgtblue's Avatar
Urban Combat Vet
Just flushed mine a few weeks back for a new radiator and removed both plugs. Alot of coolant drains from that engine plug.
Old May 8, 2005 | 12:28 PM
tt2323's Avatar
Import Connoisseur
I undid both plugs, out with the old in with the new
Old May 9, 2005 | 05:09 AM
b0ng's Avatar
a.k.a. bron
Fantastic..thanks guys for sharing!
Old May 9, 2005 | 08:14 AM
since summer is here soon, I might have to try it.... hehe
Old May 9, 2005 | 09:00 AM
potatochobit's Avatar
after you drain from the engine plug how did u fill it back up?
you use the heater hose in the UIM/surge tank or u just slowly filled from radiator cap?
Old May 9, 2005 | 09:09 AM
RX 4 Speed's Avatar
1993 VR FD Touring
I've flushed mine a couple of times and didn't undo that plug. I just undid the main plug, drained what was in there. Plugged it back up, filled it with distilled H20, ran the car for 5 minutes, drained again, repeated the process untill H20 runs clear, then filled it with coolant mix... Doesn't hurt to undo both plugs though, up to you.
Old May 9, 2005 | 09:56 AM
Mazdabation's Avatar
Is it easy to get to the second plug or is it blocked by the under tray? I know the under tray is aesy to take off but i dont have a lot of room under my car to work.
Old May 9, 2005 | 02:15 PM
Rated R1's Avatar
Oji San
I am helping a guy replace his engine and I completely forgot about that plug. Thanks for posting this. We won't make such a big coolant mess when we get the engine out now.
Old May 9, 2005 | 02:47 PM
rx7dv8's Avatar
Its very easy to get to...just go jack it up and youll see it.
Old May 9, 2005 | 03:06 PM
rx7dv8's Avatar
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
