grounding stripes, a must?
Old May 7, 2005 | 07:16 PM
rotorypolo's Avatar
73 13B 4 port
While I am having the motor out for the rebuilt, what else should I replace?
So far I have replaced all coolent hoses, a few turbo vacummn hoses, radiator, gaskets and seals.
I am also considering replaceing the oil metering lines, fuel pump, and grounding, any comments or recommendations?
Thanks
Old May 7, 2005 | 09:18 PM
mgoddard1's Avatar
I luv my carbon footprint
Grounding stripes?
If you're still running the stock injectors this would be a good time to take them out and get them cleaned and put new o-rings on them. If your fuel pulsation dampener is original I'd replace that too. If you have a mityvac I'd test all the solenoids and check valves while you have them out. Replacing the OMP lines is considered to be good practice when rebuilding a motor.
ls1swap
Jun 3, 2024 03:25 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
