puff of blue smoke????
Old Jan 2, 2002 | 07:46 AM
Mr. Mahtab's Avatar
Question puff of blue smoke????
When I start up my car in the morning there is a puff of blue smoke upon initial start. But, it goes away after a few seconds. I have 7K on a new engine and I run Redline synthetic engine oil. It this puff normal? It's been doing it since I had 2K on it. Opinions welcome…
Old Jan 2, 2002 | 09:28 AM
weaklink's Avatar
Resident Retard
normal
Old Jan 2, 2002 | 09:29 AM
weaklink's Avatar
Resident Retard
oh yeah, what ECU do you run?
Old Jan 3, 2002 | 12:26 AM
Mr. Mahtab's Avatar
stock ECU ...normally my boost goes up to about 12 lbs...max 13 lbs.
Pettit said it wouldnt go any higher... whats your thoughts?
Old Jan 3, 2002 | 12:29 AM
slopoke's Avatar
the general consenses tends to believe its normal, mine does it if it makes you feel better
Old Jan 3, 2002 | 01:49 AM
badass7's Avatar
Pimpin Rotors...and Hoes
Is it a Large puff?? Just curious because since getting my motor rebuilt it will let off a good sized puff of bluish smoke then Immediately go away. Also, if you are running a premix like I am you have to consider that as well...especially non synthetics that don't have a clean burning properties. I tested out some marvel mystery oil in my lawnmower this past summer and it blew some major bluish smoke !! However, it mowed my lawn smooth and seemed to increase in hp haha !
Old Jan 3, 2002 | 12:59 PM
7-sins's Avatar
thats not paint....
I have about 6k on a rebuild...... and it likes to blow some smoke on startup every once in a while. I've hurd it is fine so I am not that worried but it looks like ****.
Old Jan 3, 2002 | 02:36 PM
RavenRx7's Avatar
same here man.... it's for like 30 seconds -- that's it.
Old Jan 3, 2002 | 09:09 PM
maxpesce's Avatar
Ex fd *****
My rebuilt motor (and before rebuilding also but much worse) has done the same since forever and I have been assured it is normal.
Old Jan 3, 2002 | 09:29 PM
Mr. Mahtab's Avatar
that is true ...I am running pre mix from pettit..
Old Jan 3, 2002 | 10:49 PM
jeff8932612's Avatar
what if you have bluish smoke upon startup of an original motor w/ 106k miles for about a minute? Not to good huh?
Old Jan 4, 2002 | 08:51 AM
weaklink's Avatar
Resident Retard
hell if you have startup @ 106K I think you're doing pretty damn good!
ls1swap
Jun 3, 2024 03:25 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
