?s about my new FD
Old May 4, 2005 | 09:24 PM
plaguepunx's Avatar
Question ?s about my new FD
I just got a 94 rx7. It has the spoiler and lip like a R2 but it has single oil cooler, sunroof and tan leather seats? It has greddy Ti exhasut, HKS intake HKS DP, Pettit ECU and some other mods. Anyway the first day I bring it home I pop the hood and see the DP glowing red after light driving. I have done some searches and it think it may be a clogged cat. So it brings me to my first ? is it safe to run a MP w/ the Pettit ECU. Also the car idles at about 1500 rpm and at idle the vacuum is at about 16 or 17. Does that sound right?
Old May 4, 2005 | 09:31 PM
oneflytrini's Avatar
Stabbed by a pen
ALL the Pettit ECU's that I have seen have a map for a full exhaust(dp-mp-cb) and at least an intake system...
Old May 4, 2005 | 09:37 PM
MR_Rick's Avatar
Planning my come back
not all Pettit ECU are like that I think. Some of them are taylor to the customer specification. At least that's what I understood from the old limited ECU's
Old May 4, 2005 | 09:53 PM
c h I n e Z e~BoY's Avatar
idle doesnt sound right man. it should be around 700-800 rpms
Old May 4, 2005 | 10:13 PM
Mahjik's Avatar
Mr. Links
The Pettit ECU only has one map. The only difference is the fuel cut limit (between Limited 14.7 PSI and Unlimited).
Old May 4, 2005 | 10:32 PM
plaguepunx's Avatar
Thanx for the speedy responds. Yeah I dont know what is with the idle. When I cruise at 2.5k and put it in neutral it will hang at around 2k until i give a tap on the gas.
Old May 5, 2005 | 12:47 AM
1revn3rdgen's Avatar
You shouldn't have a problem if you add a midpipe.I had the same problem, my idle was at about 1200rpm, but if i lowered it the car would want to turn off.I think you might need a better ecu.I think i had that problem because i also had a large street port and i needed a better ecu like a stand alone.
Old May 5, 2005 | 01:06 AM
JOSH FRANCO's Avatar
RX-7-VETTE
Is the motor street ported?
Old May 5, 2005 | 11:27 AM
`sl!mXP's Avatar
I
its a touring model most likely - its more likely that the previous owner added a lip than took away an oil cooler :P
The idle is definetly high for a stock motor, my streetported motor doesnt even idle that high - but putting a mp and new ecu in could fix the idle problem.
Old May 6, 2005 | 10:10 AM
plaguepunx's Avatar
Yeah im pretty sure its a touring. It says special edition by the VIN on the passenger door? I dont think the motor is ported because it was rebuilt by the mazda dealer :P (less then 10k) I am going to do a tune up this weekend. I think there may be a vacuum leak too because it sounds like there is one near the TB area.
Old May 6, 2005 | 10:27 AM
JTurtonRX_7's Avatar
EFR IWG 8374
the high idle could be several things
#1 cause of high idle Vacuum leak. Check all your vacuum hoses and check or replace the easy to get to gaskets (UIM to LIM / IAC / AWS / TB to UIM)
#2 adjust your Air idle screw (under the throttle body)
#3 make sure your Throttle position sensor is not out of wack.
Old May 6, 2005 | 10:39 AM
plaguepunx's Avatar
Yeah I plan to adjust the tps and check for any gasket and vacuum leaks when do the tune up this weekend.
Old May 6, 2005 | 10:59 AM
DaveW's Avatar
Racecar - Formula 2000
The glowing DP could JUST be the result of the fast idle. Fix that before you worry about the pre-cat (stock DP). If you have more symptoms after fixing the idle - still glowing after light driving, low boost, etc., then worry about clogged cats.
Old May 6, 2005 | 11:16 AM
rynberg's Avatar
Installing a midpipe will likely result in bad spiking and boost creep. You don't even have a boost controller yet. The main cat rarely fails unless the pre-cat takes it out or you are running way too rich for a significant period of time (or your airpump isn't working).
If it truly has failed, I would install a hi-flow cat instead of a midpipe at your modding stage and familiarity with the car.
Old May 7, 2005 | 05:48 PM
plaguepunx's Avatar
Ok guys I went to put some new gaskets on and I found out that the top right stud on the TB is stripped...badly stripped. So now I have to either get a new TB.
Old May 7, 2005 | 05:54 PM
Mahjik's Avatar
Mr. Links
Grab the stud with vice grips and turn it out. Then replace with new stud.
Old May 7, 2005 | 06:37 PM
quicksilver_rx7's Avatar
Tan leather seats
must be a touring model
Old May 7, 2005 | 07:14 PM
plaguepunx's Avatar
Just tired and I couldnt get it out. It just twists but doesnt budge
Old May 7, 2005 | 08:41 PM
plaguepunx's Avatar
ahaha thought it was pressed in. I got it out but thet didnt have anything at Pep boys or at Home Depot. Any idea where to get one?
Old May 7, 2005 | 09:44 PM
Mahjik's Avatar
Mr. Links
Most likely you aren't going to fine an "exact" stud anywhere but the dealer (I've already tried before).
You have 2 options:
1. Go to Westlake/Ace Hardware. Get a bolt that will thread into the TB and then cut to fit as a stud.
2. Just remove all the other studs and use bolts to hold it instead.
Old May 7, 2005 | 09:48 PM
plaguepunx's Avatar
Yeah I just found another bolt and cut it. I am about to start it up right now.
Old May 8, 2005 | 08:05 PM
plaguepunx's Avatar
Ok so it runs and I got the TB all cleared up but now it has a loopy/surging idle. It will go up like 200-300 rpms then it goes back down over and over again...its really annoying.
Old May 8, 2005 | 08:20 PM
witepsycho's Avatar
mine does the same thing...sorry im not tryin to steal your thread, but my car idles high too...i think the guages might be off a little too though...i had aftermarket ones installed and i think they fucked it up...my car reads like 2k-2500 at idle. i have a 3" DP and a 3" cat-back...could it be idling high because of that?? the car only has 40k miles on it...and the high idle only started once i put the exhaust on there...
Old May 8, 2005 | 08:39 PM
Narfle's Avatar
Rx7 Wagon
a vacuum leak will often screw up your idle. i suggest you do the hose job nxt weekend.
Old May 8, 2005 | 09:39 PM
witepsycho's Avatar
how long does that take???
