Microtech Wide band?
Old May 2, 2005 | 02:38 PM
Wide band?
I am thinking of buying a PLX M-300 wide band, will this work ok with my Lt-8s?
Has anyone had any experiance with this wide band? do they work ok? no problems?
Cheers
Chris
Old May 2, 2005 | 07:20 PM
I've done alot of searching tonight and have decided that i want a wide band with datalogging.
SO, I am now thinking of going with a Innovative LM-1.
I have a buget of about $400 and for a little bit more i can get the RPM kit on it too?
What do you guys think? i'm a bit confused myself, i want a good wideband as i'm a bit of a newbie to the setting up side of the Rotary world. The more i read the more indicisive i get.
Chris
Old May 2, 2005 | 07:31 PM
Chris
Old May 3, 2005 | 02:01 PM
Jon Goodwin's Avatar
Hi Chris,
Sorry i did not reply your email. I do have a fair bit of experiance with the microtech. Widebands.. the LM-1 is damn good, and Pip should have one on the shelf, if i remember correctly.
John
Old May 4, 2005 | 01:24 AM
FC_mania's Avatar
no one can suggest him some good brands?
im using PLX M500 myself. how is the Innovate one works ? does it datalog with the microtech or by itself?
Old May 4, 2005 | 04:29 AM
onefastrx7's Avatar
Yes, good questions, does the LM1 datalog on the Microtech screen? I know the LT8S accepts 0-1V narrow band, and the LM1 can output 0-1Vand I can define the low and high. But has anybody tested the MT along with the LM-1?
Old May 4, 2005 | 06:52 PM
fastcarfreak's Avatar
3rd motors a charm I hope
Im pretty sure the LT12s is the only microtech unit that lets you hook a wideband up to it.
Old May 4, 2005 | 10:45 PM
onefastrx7's Avatar
Well, if the LTX8 is configured to read 0-1V and 11-19 AFR in a linear fashion, I can hook up the LM1 and program it to provide an output of 0-1V for AFR points between 11:1 and 19:1 on the LM1 screen.
Old May 23, 2005 | 09:32 PM
BOOSTED Vert
so what is the most that the norrow band can reAd? afr...
Old Jun 1, 2005 | 02:25 AM
dr.jones63's Avatar
It's a Hammer
The LT8 doesn't accept a WB signal. I have a Zeitronix and you can plug the narrow band output into the LT8. If I had a ECU that took a WB signal I would want one that had a linear WB output, but I don't so the zeitronix is fine and a little cheaper. You can always just open up 2 windows on your laptop and data log both indepedently too.
Old Jul 19, 2005 | 02:39 AM
Havoc's Avatar
does anyone know if a wideband or a narrow band will work or plug into the microtech mtx8 ?
I know its a older model but just wondering ?? also is it really worth while ?
Old Jul 19, 2005 | 06:40 AM
ggoldfingerd's Avatar
I've been searching for different wideband set-ups and the a lot of people really like the LM-1. Anyone have thoughts about other wideband set-ups?
Logan Reinisch
44
Sep 17, 2018 12:20 PM
manoflego
19
Sep 30, 2015 05:19 AM
