Question on Blockoff Plates
Old Dec 31, 2001 | 07:54 AM
Question Question on Blockoff Plates
I made all of the blockoff plates for my car and I was wondering what resistors I needed to put in the connectors so it won't throw a check engine code. The connectors I am refering to are the three sensors that are on the port air control (I think that is the big valve on the back of the manifold above the injector rail) , the air pump stuff runs through it. Any help would be appriciated.
Old Dec 31, 2001 | 08:07 AM
Sleeper's Avatar
DOnt mean to be an idiot but what the hell is a blockoff plate?
Old Dec 31, 2001 | 09:18 AM
Chadwick's Avatar
Mr Sparkles
They use a 330ohm 1/2 watt resistor.
Dan
Old Dec 31, 2001 | 11:12 AM
Wargasm's Avatar
Weird Cat Man
What's the harm in just removing the solenoids and leaving it like that? Why go to the trouble to put in resistors? Will the car go into limp mode or something???
Brian
Old Dec 31, 2001 | 01:22 PM
jumprdude's Avatar
Brian
If the ECU does not see the impedance equivalent of the solenoid on the control lines it will trigger the check engine light and toggle an error code.
83revival
Sep 3, 2015 10:42 PM
