Power FC Caution!
Old Dec 30, 2001 | 11:56 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Caution!
Do not use the ignition maps for the TO4S... I actually set it up a couple deg. less on the top end and got 1 and 1/2 runs out of it... I now have no compression on the front rotor... Looks like it's time for a full bridge..
Old Dec 30, 2001 | 01:21 PM
Tim Benton's Avatar
FD title holder since 94
Man that sucks ***. What kind of knock number did you see when the front rotor went POOF? Was it do to knock (pre-ignition), to lean of a mixture, timing advanced to much?
Tim Benton
Old Dec 30, 2001 | 01:31 PM
Dragon's Avatar
I didn't get to see the knock #, but it was showing consistant 100-140's on the way home running on one rotor... It was definitly Ignition, to much timing advance... I've got plenty of fuel..
Old Dec 30, 2001 | 09:25 PM
Tim Benton's Avatar
I haven't looked at the map for the To4 since I don't have that setup but how does it compare to the stock maps? Hey Scott's new site can do that Was this a map you got straight from XS or the posted one?
Man, that still sucks about the engine.
Tim Benton
Old Dec 30, 2001 | 11:31 PM
Dragon's Avatar
The one that was posted... don't use the fuel map either, it is obvious that that computer has a rewritten base map, I was just going to try the ig map, but was still using my fuel map when she died... No compression on the entire front rotor, but I have every thing to build a new engine , just no time rignt now...
Old Dec 30, 2001 | 11:36 PM
skotx's Avatar
Registered Abuser
Unfortunately, just like everyone else I can't get to the maps on the board. I'm really hesitant about putting that one up, but I guess it would be interesting for comparison purposes. I'll put big warnings on it and maybe explain how XS tunes their maps differently, to help the newbies.
Old Dec 31, 2001 | 03:53 PM
Dragon's Avatar
Unhappy
If they ever start selling the data logging stuff it would help greatly... It's hard to tune a rotory espicially with tons of mods on the street, it's all trial and error, the error part get's expensive and time consuming....
But it's a good excuse to put in a Bridge port...
O' I'm running a To4R...
Old Jan 1, 2002 | 11:52 AM
Dragon's Avatar
I'm in Okinawa, Not mainland Japan, there is one power excell dealer here and they suck... You guys probably have it made better than me.. O' and Japanese have never heard of an injecter over 1000cc's every shop I've been too tells me I'm lying when I tell them I have 1,600cc injectors, they always say nobody makes injectors that big...
Old Jan 2, 2002 | 02:32 AM
machinehead's Avatar
kortez
That is way too funny!
Sucks about your engine though, sorry to hear that. Before i had XS tune my PFC I ran those maps posted above (you know they are not from XS, right?), as I was entering them in I noticed that they seemed very agressive so I used one of Chucks Ignition maps instead. I guess it was a good idea.
Old Jan 2, 2002 | 05:32 PM
SPOautos's Avatar
Hey, where did my $$$ go?
You think using the ign from one map and fuel from another is what caused the prob? The ign and fuel have a delicate relationship together. The fuel map and ign map you were using were not tuned for eachother.
I havent seen either map, I'm just saying that its possible.
Oh yea, if 1000cc is the biggest in Japan what do they do? They must add more injectors or something?
Later,
STEPHEN
Old Jan 2, 2002 | 08:36 PM
kortez
I guess that in Japan they must only have the ND injectors, since the big ones are Bosch they just aren't familiar with them. Just a guess...
Old Jan 2, 2002 | 08:39 PM
jspecracer7's Avatar
1JZ powered
nah...they just add 4 X 1000cc injectors most of the time....or they ask americans to order them the 1600 injectors
erevos
Sep 15, 2015 09:19 AM
Badappex
Jul 17, 2003 11:23 PM
powermalex
Apr 9, 2003 06:57 PM
