Track Worthy?
Old Apr 23, 2005 | 01:41 PM
RidicilousRx7's Avatar
1993 Mazda RX7 R1
Track Worthy?
hey guys, yesterday i took my 87 S5 T2 out to the track. i need info on new rotors and pads and where to buy them. also what would be some good but inexpensive tires to wrap around the original 87 T2 rims? all info is greatly appriciated.
Old Apr 23, 2005 | 01:47 PM
1993 Mazda RX7 R1
btw i dont mind if the brakes squeal while being driven around town. alsong as they hold up on the track. thanks
Old Apr 23, 2005 | 03:09 PM
rynberg's Avatar
If you are just starting to track the car, maybe "dual-use" brake pads will work for you -- for now. In the end though, you're going to have to start using real track pads at the track.
I would just get solid-face or slotted, vented rotors to replace your stock rotors. Do not get cross-drilled. Decent "dual-use" pads I've used are Hawk HP+ (nasty dust and light-braking squeal). Others have used EBC Reds, Axxis Ultimate, Porterfield R4S to varying degrees of success.
You can get some of these products from the Tire Rack, others from several of the other bigger online stores.
Coochas
44
Nov 5, 2019 11:08 PM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
