Microtech injectors not working while cranking
Old Apr 21, 2005 | 01:26 PM
JIMMY54's Avatar
GSL-SE PRO
Hey
Well in test mode, the injectors fire along w/ coils etc. However when in normal mode, they dont fire the injectors but the coils work still. Also i notice that when in test mode it shows the timing/rpm/injector pulse , yet when i crank normally none of this works.
I've been reading through a bunch of old threads but still nothing
Old Apr 21, 2005 | 05:52 PM
10sec rx7's Avatar
you havent got the primarys and secondarys wired back to front?? the wiring to the cas is right??
Old Apr 21, 2005 | 07:26 PM
JIMMY54's Avatar
GSL-SE PRO
All the wiring seems good. However i have discovered that it seems my acutal injectors are not working. I tested the injector wires w/ one of those node testers (you plug it in where the injector should be and it will flash whenever the injector was supposed to be fired)
Either i dont have enough fuel pressure to open the injectors, OR they are stuck closed(which is quite possible as they were cleaned after been clogged but never used, and i was told if i let them sit they may stick again)
I'll know for sure tommmrow once i get them cleaned again.
Old Apr 28, 2005 | 12:16 PM
aruba's Avatar
i have the same problem
the engine cranks but no injector impulse
at how much do i need to have the fuel pressure at????
do the injectors axually need a specific pressure to open???
i have it set around 35-38 psi???
I'am using 4 1600cc injectors
Old May 26, 2005 | 09:26 AM
I F****D a mermaiiiid
you shouldn't need ANY fuel pressure to open or close the injectors.
i usually test suspect injectors with a 9volt battery. i give it a couple of little taps on the terminals and listen for clicking and watch the pintle move.
Ray
Old May 26, 2005 | 11:16 AM
10thAnivTurbo2's Avatar
is your power source for the injectors the same as your coils, or two diff power sources?
Ive seen some people use a power source that provides power when ign is "on" but not when cranking. Just an idea.
Old Jun 16, 2005 | 08:50 PM
JIMMY54's Avatar
GSL-SE PRO
Acutally what ended up happening was a combination of things.... My injectors were firing, BUT they were clogged due to sitting for a long period, so once they were cleaned, no issues. As for my spark, The problem was that my switched 12V would turn off during cranking so i had to take it from somewhere else.
befarrer
Aug 14, 2015 04:18 PM
