Supercharged 13B in Karmann Ghia
Old Apr 19, 2005 | 05:22 PM
70ghiavert's Avatar
I finally got the engine running. It is a street ported 13B with a Candem supercharger and a 650 holley.
Old Apr 19, 2005 | 05:27 PM
Atkins Dan's Avatar
Former Site Sponsor
l00ks g00d!!!!!
How well does it run for you???
Old Apr 19, 2005 | 05:40 PM
Node's Avatar
badass. how do those handle? can you swap lots of porsche stuff onto them?
saw a guy w/ some nice recaros and a mostly porsche motor in one. very nice
had some fuchs and was pretty lowered. sweet sleeper
Old Apr 19, 2005 | 05:44 PM
70ghiavert's Avatar
The engine runs really good! I have not being able to take it out on the street. The temperature is staying around 185 degrees.
I need to install the gauges on the dash. The wires you see going up the firewall are a temporary connection for the gauges.
I will let you know when I get to take the first drive.
Old Apr 19, 2005 | 08:03 PM
Fd3BOOST's Avatar
Recovering Milkaholic
IRS or swing arm in that one?
Anyway looks like a nice install. Any exterior shots?
Old Apr 19, 2005 | 08:08 PM
70ghiavert's Avatar
I have Porche fuch wheels for it and is getting recaro seats. I bought this car about 5 years ago and have since upgraded the tranny and vw engine. I know installed the rotary and am in the process of having the body and interior redone. Now that the engine is running is time to refinish (again) the engine compartment and take it to a shop for the body work. It is a lot of fun to drive.
Old Apr 19, 2005 | 08:14 PM
70ghiavert's Avatar
It has an IRS. The exterior is not done yet. It is going to a shop for the exterior and interior. It still have a few months to go before it is ready. You can see a couple extra pictures of what has been done at:
http://www.geocities.com/ed0617/
Old Apr 19, 2005 | 09:33 PM
clean85owner's Avatar
Nigga stole my bike!
Is that the 5" or 7" supercharger on that motor? Also, is it a 4 port or 6 port? Do you have any clue as to what kind of power you are making.
I would really love to put a 7" on my SP 13B 4 port....
Old Apr 19, 2005 | 10:12 PM
70ghiavert's Avatar
It is a 7" supercharger. The engine is a 6 port, S-5.
Old Apr 19, 2005 | 10:42 PM
Elysian's Avatar
Bimmer *****
that is such a sweet looking car...
Old Apr 19, 2005 | 10:47 PM
Alak's Avatar
How did you get the VW Tranny hooked up to the 13B?
Old Apr 20, 2005 | 09:02 AM
70ghiavert's Avatar
Kennedy Engineering Products fabricates adapters for almost any type of engine. See the link:
http://www.kennedyeng.com/
Old Apr 20, 2005 | 09:07 AM
70ghiavert's Avatar
I will not know for sure until I cantake it to a dyno. I would assume that if the engine has about 160 to 170 hp with the street porting, header and 650 holley and the supercharger gives me another 30%, the hp should be between 208 to 230. We will see.
Old Apr 20, 2005 | 11:09 AM
13btnos's Avatar
On your oil cooler what brand is it and what are the specs on it? Car looks sweet and I really like the oil cooler you choose to use. What are your oil temps like and what size hose/fittings did you use? Great looking ride.
Old Apr 20, 2005 | 12:33 PM
Fd3BOOST's Avatar
Which transaxle are you using anyway?
Old Apr 20, 2005 | 01:01 PM
fishbulb95's Avatar
DisaffectedCollegeStudent
Sweet Car ...
let us know the specs after the Dyno
Old Apr 20, 2005 | 03:41 PM
vdo_game_junkie's Avatar
Nice. I wanted a Ghia long time ago. In high school, one of my sister's friends had one witha 914 engine in it. I can't wait to see how yours turns out.
Old Apr 20, 2005 | 05:21 PM
jgrewe's Avatar
GET OFF MY LAWN
Just a hunch, but I'll bet you'll need a fan on your oil cooler. And it looks like you kept the AC compressor, very nice!! Now if you can mount some fake stock chrome tail pipes on the back... I have a '66 convert ghia waiting for redo this gives me ideas. Have fun, don't kill yourself in it.
Old Apr 20, 2005 | 08:59 PM
70ghiavert's Avatar
It is a Setrab Oil Cooler. It has dual fans. I believe it is used on Nascar cars. The oil temperatures are staying below 180 so far. That is without runing the engine at high RPMs (breaking-in the engine).
I used -10 AN fittings and lines from the engine to the cooler and then installed reducers to -8 AN to be able to use the temperature sensor that I bought with the cooler.
Thanks!
Old Apr 20, 2005 | 09:07 PM
70ghiavert's Avatar
I am using a VW transaxle from Rancho Performance. It is what they called a PRo Street - hardened keys, Super Diff, Aluminum Side Cover, Welded 3-4 Hubs.
I bought it before I decided to go with a rotary engine. It has a 3.78 ratio.
Old Apr 21, 2005 | 03:34 PM
Alak's Avatar
Rotary Rocket.
Im working on plans for a Rotary Dune Buggy. Thanks for the info on the tranny adapters.
Old Apr 22, 2005 | 02:17 PM
RX7UP's Avatar
BOYCOTT EXXON MOBIL!!!
lookin good.... I'll bet you are a proud father...
Old Apr 23, 2005 | 02:03 PM
PhucNguyen57's Avatar
nice swap
http://frost.bbboy.net/vwengineconversions
I'm glad I found this link on your site. I've been wanting to put a diesel in my 74 bus.
Old May 7, 2005 | 04:22 PM
sweet86's Avatar
That swap looks sweet . I've been thinking of going carb on my turbo and my non turbo engines. Can't wait to see it when its done.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
