turbo break in
Old Apr 12, 2005 | 07:23 PM
full-cruise's Avatar
D.I.L.U.S.I.
Question turbo break in
hey i just picked up a new turbo and wanted to ask how many miles it will take to break it in?
Old Apr 12, 2005 | 08:10 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
turbos do not require break in.
they do require pre-oiling. pull your fuel and ignition fuses and crank the motor over til you see oil pressure.... crank it over a little more.
you are good to go.
howard coleman
Old Apr 12, 2005 | 09:13 PM
88fc3sw/HX83's Avatar
I've been told a LONG time ago that 500 miles is good, but todays turbos may be different.
Old Apr 12, 2005 | 09:39 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I dont know about break in, but on my new turbo, it took about a day of driving before the turbo loosened up and started spooling faster.
Old Apr 13, 2005 | 02:40 AM
SpoolinRX's Avatar
OFENSIV
When we gonna meet up man, I am still down for that smoke.
Old Apr 15, 2005 | 09:09 PM
D.I.L.U.S.I.
bump
Old Apr 15, 2005 | 09:17 PM
rx7tt95's Avatar
Photo Diety
A bearing is a bearing...they all need a bit of break in. My proceedure by way of CLR's recommendations is to disable the ignition, turn the car over in 20 second intervals until oil pressure starts to show on the car's gauge. Leave the turbo's oil feed line loose or have a friend point it into a bottle. Once oil starts to flow out the feed line, connect it back up. Keep the turbo from spinning by using a socket/breaker bar or wratchet over the compressor's nut. Mine was 15mm. Start the car. Once the oil line gets hot, pull off the socket and let the turbo spin up. It'll start to do so slowly and then speed up. After that, I'd give it at least a hundred miles of gentle break in. Don't go pushing 100K rpm and large amounts of boost! I'm assuming you're going to have to retune anyway. You could also call the turbo's manufacturer and see what they recommend for a break in period.
Old Apr 17, 2005 | 12:02 PM
D.I.L.U.S.I.
[QUOTE=Keep the turbo from spinning by using a socket/breaker bar or wratchet over the compressor's nut. Mine was 15mm. Start the car. Once the oil line gets hot, pull off the socket and let the turbo spin up. It'll start to do so slowly and then speed up. After that, I'd give it at least a hundred miles of gentle break in. Don't go pushing 100K rpm and large amounts of boost! I'm assuming you're going to have to retune anyway. You could also call the turbo's manufacturer and see what they recommend for a break in period.[/QUOTE]
i never herd of this... whats the point of holding the turbo?
Old Apr 17, 2005 | 03:20 PM
rx7tt95's Avatar
Photo Diety
Cold oil won't lubricate enough to keep the bearings from wearing. By waiting until the oil is hot, you make sure it's being properly lubed.
cristoDathird
28
May 30, 2019 08:47 PM
PhillyFC
Aug 21, 2015 06:36 PM
tsmith94FD
Aug 16, 2015 05:41 PM
ncds_fc
Aug 15, 2015 10:06 AM
