Widest Tire On 17X7
Old Apr 10, 2005 | 07:12 PM
Widest Tire On 17X7
I currently have 215/45-17 Yokohama AVS1 100 on all four corners. I would like to know the widest tire I can safely run on a rim that is 7" wide.
Thanx
Michael
Old Apr 10, 2005 | 07:53 PM
WanKeL FD RX-7's Avatar
Rotary addict since 86
thats pretty the widest you can go...
Old Apr 10, 2005 | 08:00 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
Depends on the tire model you wnat to run..
Check the specs for eachtire on tirerack. they specify the "acceptable range of wheel widths" for each tire model... Go with what teh manufacture of teh tire suggests...
Old Apr 10, 2005 | 08:32 PM
rynberg's Avatar
Most tire manfs list a 17x7" wheel as being the minimum acceptable for a 225/45 17 tire. That is as wide as you can go, although functionally, they will be little different from your existing tires.
Old Apr 10, 2005 | 09:26 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
What happenes is that as you go wider tire widths, the sidewalls buldge in at the bottom.. making sort of a donut looking wheels/tire combo.. like on those old sand buggys.. this has the effect of reducing the sidewalls resistance to flexing because the cords are already flexed.. sometimes you want that.. like in offroad tires.. but you don't want it on a sports car
225 are about it..
Also... you'll get into fitment problems on the front with anything bigger if you are running stock offsets.
Old Apr 11, 2005 | 10:56 AM
AdamBench's Avatar
i have a friend with 7 inch rims and he has 245's on em they are fine they pudge a little but they are ok
i put 235's on my old car on seven inch rims all the time anything up to a 245 is fine
Old Apr 11, 2005 | 11:05 AM
gnx7's Avatar
A 225 is about the max on a 7" rim. I had 245/50/16's on some 16x7's but they bulged badly! I would not recommend this if you want the car to handle. Mine was setup for drag.
Old Apr 11, 2005 | 12:22 PM
rynberg's Avatar
Just because you can physically mount them on a wheel doesn't mean it's ok. Tire manufacturers do not support a 235+ being mounted on a 17x7" wide wheel. Period.
245s on a 7 will handle worse than 225s on a 7...
Old Apr 11, 2005 | 04:47 PM
adam c's Avatar
Cheap Bastard
225 max on 7 inch rims. Handling will suffer with wider rims. Of course, your handing is already suffering with those ES100 tires
Old Apr 12, 2005 | 04:58 AM
maxcooper's Avatar
WWFSMD
It also depends on the sidewall height / aspect ratio. For example: A 265/70-17 light truck tire fits on a 7" wheel, but the widest BFG KD that fits on a 7" wheel is a 225/45-17.
-Max
Old Apr 12, 2005 | 10:21 AM
rynberg's Avatar
-Max
True, Max, but I was assuming he wasn't putting a 6" lift kit on his FC...
rx7jocke
72
Jun 17, 2016 03:48 AM
