Haltech haltech problems
Old Apr 8, 2005 | 06:53 PM
ronbros3's Avatar
haltech problems
seems it starts hard and runs only on rear rotor, very rich, could the front be so rich it wont fire , new motor rebilt, checked compression 110 on all chambers front and rear whew! had me wondering. any input would help. RON
Old Apr 9, 2005 | 02:03 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Did you wire up the injection connections correctly? the only reason for something like that to happen is bad wiring, or miss connecting the injector plugs, or even a wrong setting in the software. Or worst case scenario is something wrong with your injectors or plugs are fowled, or even improper tuning.
Remember to set the proper configuration, and that inj1 and inj2 go to both primary injectors, and inj3 and 4 go to the secondary ones.
Old Apr 9, 2005 | 04:19 PM
ronbros3's Avatar
THANKS Claudio Im pulling the UIM, and will get injectors tested, also go over the wiring .
Old Apr 9, 2005 | 09:13 PM
EFI Tech Wannabe
Good luck, i always make it a priority to mark each connector properly so know where everything goes easily.
Old Apr 10, 2005 | 07:27 AM
RETed's Avatar
Rebuild broken in yet?
If not, this is a royal pain in the *** to make it work...
-Ted
Old Apr 10, 2005 | 02:08 PM
EFI Tech Wannabe
-Ted
That is another point, sometimes a fresh rebuild, depending on how it was done, will take a few miles to brake in and seal properly, but if your engine is giving you 110 on all sides its perfect, so my guess is that you have something miss connected or miss configured. Start at the injector plugs and go from there, also, are the coils properly wired, configured? that could also be it. It took me a few tries to get the wiring and settings down on the X.
Old Apr 10, 2005 | 07:10 PM
tims's Avatar
new spark plugs and some spares for later.
Old Apr 11, 2005 | 04:02 PM
ronbros3's Avatar
where do I get a wiring diagram for an E6K, I have no install book or info about system, car came in not running with blown motor, new seals all, good used rotor housings,new side plates, 2 good used 3 mm rotors, so IM not sure how it run before blow up. thanks again RON PS how long does average rotary take to seal up or break in, in miles
Old Apr 11, 2005 | 07:47 PM
EFI Tech Wannabe
Depending on who did the rebuild, how knowledgeable they are, and engine can seal right away, or it can take over 500 miles. But its good practice to let a freshly rebuilt engine to break in properly, with around that much miles covered.
Download both the manual AND the wiring diagram from the download section of the Haltech website.
Old Apr 12, 2005 | 11:42 AM
ronbros3's Avatar
HI Claudio , haltech probs.
well I took out injectors, sent for testing , says all flow good , both sec, and primarys put them back in same places, decided to put injector leads on prims. reversed 2 on #1, 1 on #2. now it run on front rotor not rear! took out plugs , prims. put in new ones, YEA! run on both smooth as silk ,{ BOY rotarys are wierd maybe felix's DNA is from another planet.} but now comes the infamous tuning sessions. I have a laptop but no software for E6K, I have some experience on Microtech and SDS systems install and tuning. and I only mean some. thanks RON
Old Apr 13, 2005 | 01:42 AM
dznutzuk's Avatar
Uncontrollable drifter
Just go to www.haltech.com and download the software.
Old Apr 15, 2005 | 01:50 PM
ronbros3's Avatar
HI ! THANKS GUYS for your help. TO Claudio for keeping my courage up, THANKS to TED from HI. for input on CROWN ROYAL pain in the ***, and TIMS, for me installing 3 sets of plugs, 2nd set # 5s hot with 2 gaskets under them to keep oil away from the plug until I could warm it up good, plus not hit the rotor. of course 8 months of settling premix didnt help. runs almost perfect. damn rotarys are temper-mental. RON DAYTONA
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
