In tank fuel pump?
Old Apr 7, 2005 | 05:40 PM
vietxdragon's Avatar
In tank fuel pump?
i finally resurrecting my rex n/a but i found out that the fuel pump is dead and the tank is full of crap. What have you guys replaced your pumps with? where can i get one over the net for cheap? i've seen walbro's on ebay for 100 is that any good?
Old Apr 7, 2005 | 05:52 PM
BlaCkPlaGUE's Avatar
I live in an igloo
www.injector.com
www.rx7store.net
Those were the two places that I was going to buy from if I ever needed one. Keep in mind, that if its not stock, your going to need a better fuel pressure regulator im pretty sure, as the pressure will be really high with the pumps that these guys sell. Im not to sure on that, but we'll wait for some other replys to confirm if im dead wrong or right ;0
Old Apr 7, 2005 | 08:28 PM
yeah thats what i was wondering if i were to buy a aftermarket pump, would it mean i would have to upgrade everything else?
Old Apr 7, 2005 | 11:48 PM
MrSparkle's Avatar
i'm disrespectful to dirt
if you don't have any mods you don't need an aftermarket pump. you get the pump when you need more fuel for the mods.
Old Apr 8, 2005 | 12:32 AM
Impreza2RX7's Avatar
Buy a stock pump for your needs.
Old Apr 9, 2005 | 12:36 PM
im on a budget, and the cheapest pump i've found is a Walbro 190LPH but i cannot find a place on the net that sells them, near Michigan anyone here know a site with those pumps?
Old Apr 9, 2005 | 01:26 PM
sleejay's Avatar
omae mo na!
buy a stock pump. it puts out more than enough.
while your at it, change the screws that hold the pump assembly in the tank. the stockers suck. they are 8mm screws.
sorry to hijack, but:
i need to put a new pump in. i have a new pump, but i need to swap it into the old assembly (float, etc). i cant get that damn screw off that holds the pump itself in. any tips?
Old Apr 9, 2005 | 01:28 PM
DragonRx7's Avatar
Goes *round*round*round*
Why don't you just buy a FD fuel pump?
Old Apr 9, 2005 | 02:07 PM
pliers, or get a flat head screw driver and a hammer and hammer the screw driver into the screw and try using the flat head if its stripped, spray wd40 on it the nite b4 too, and i would get a stock pump but they're all over 150+ and thats kind of cash i dont have. wouldn't the FD fuel pumps be too much for a stock 86 n/a fuel system>?
Old Apr 9, 2005 | 02:44 PM
Richter12x2's Avatar
Taste great, more filling
If I understand correctly, your fuel pump only supplies the fuel to the injectors - you could put a fuel pump from a Peterbilt Semi in it, and it's still only going to squirt out whatever the injectors are programmed to do, so I'm sure an FD RX7 fuel pump would be fine.
Rotospectre
Mar 28, 2018 03:33 PM
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
