help!! Short shifter question
Old Dec 27, 2001 | 12:30 AM
Pumped's Avatar
hi, i bought my FD with the B&M shortshifter, theres rattling noise for 1st,2nd and 3rd gear, i talked to a transmission shop, he said it was worn out bearings. is this true? or is this noise from my shortshifter.
thanks
Old Dec 27, 2001 | 12:40 AM
Bacon's Avatar
IRS 4 Life
is the noise when your shifting into the gears, or in the gears...dose the shifter feel loose?
prob is the bearings or syncros...i havent heard of any probs with b&m
Old Dec 27, 2001 | 01:36 AM
Pumped's Avatar
the noise is there in gear not between shifts. noise is gone when in forth and fifth gear.
Old Dec 27, 2001 | 04:42 AM
mazdaspeed00's Avatar
For Sale
most likely its the bushings. honda/acura people have the same problem with the shifter ratteling while in gear when they install a shortshifter. try replacing the shifter bushings.
Old Dec 27, 2001 | 07:53 AM
Merciless's Avatar
The Love Below!!!
nah...common problem with our Fds with short shifters...even if you buy pettit or mazdatrix version....there is a chance of rattling noise...
Old Dec 27, 2001 | 08:38 AM
skotx's Avatar
Registered Abuser
merciless is right. Read what Mazdatrix has to say about it.
Old Dec 27, 2001 | 10:46 PM
Pumped's Avatar
damm this is annoying, it gets a little louder on downshifts and more gas.
the tranny guy wants $600 to fix the bearings, i just want to make sure its the bearings and not the shortshifter before i pluck down $$.
thanks guys
Old Dec 28, 2001 | 02:19 PM
thanks guys
It is not the bearings! It is what Merciless said. FD + short shifter = rattle.
If you want to check something to make you feel better, unbolt the B&M and make sure there is enough gear lube in the reservoir.
After I put my B&M on my FD it rattled a lot too. It gets better the longer it is on...or else...I just got used to it..
Later,
Patrick
Old Dec 28, 2001 | 07:10 PM
Pumped's Avatar
ok, i'll try that out
Old Dec 28, 2001 | 07:20 PM
You will have to take the shift **** off, then pull the center console plastic piece up (being careful not to break any tabs).
Then you will see 4 nuts holding a rubber boot thing down...I believe. You want to remove these nuts, then the boot thing, and any insulation. There is also a plastic collar on there. Make sure you remember what sequence these came off. You will want to put them back in the same manner.
Then you will get to the B&M. It should look like a big blue block. It will have 4 allen head bolts securing it. You will have to loosen these up and remove them. Be careful not to drop them. I am not sure where they will end up...
Then you will have to pry the B&M off because it should have RTV sealing it to the tranny housing. Once that is off, you will see fluid (you should see fluid). That is the resivour. Make sure it it full.
Reassemble in the same manner...making sure to re-apply RTV to seal the tranny housing.
Here is a helpful link:
http://www.mazdatrix.com/faq/ssinstal.htm
This will be a bit different...because it isn't a third gen, but they tell you what type of tranny fluid to use...and how much to add.
Hope that helps.
Later,
Patrick
Old Dec 30, 2001 | 09:19 PM
Pumped's Avatar
bad news, i took the short shifter out.
there is still rattling noise, sounds like a diesel engine
but its a little more quieter and i like the stock shifter alot better.
Old Dec 30, 2001 | 09:21 PM
Pumped's Avatar
Pweizman... Thanks for all the help.
Old Dec 30, 2001 | 09:27 PM
No problem...any time.
Later,
Patrick
