Turbo burning oil?
Old Apr 6, 2005 | 10:59 PM
Mindspin311's Avatar
Powered By Trochoids
Unhappy Turbo burning oil?
Well the FC I bought has presented me with its first problem. At random points while idling the car will begin to smoke, today it happened while warming up the car and 2 mins after the car had warmed up and I drove down the street and again let it idle. Oil pressure seems to be fine, the car idles smoothly so I dont know what is really wrong. My only guess is that the turbo is leaking oil, its a BNR Stage 2. I read that they have been known to leak if they receive too high of oil pressure and this is the only solution I can think of. Any insight would be greatly appreciated. Thanks!
Old Apr 6, 2005 | 11:10 PM
RotaryWeaponSE7EN's Avatar
Take it off and check all the seals on the turbo.
Old Apr 7, 2005 | 01:02 AM
DannyD's Avatar
are you still running cats?
As soon as you start your car up have someone watch the exhaust or try to watch it from the drivers seat, the way to tell is if it shoots blue smoke right away then its your oil control rings. If it doesnt smoke till after your exhaust has warmed up then its your turbo, cause your turbo wont burn the leaking oil till it is hot, but your combustion chambers are hot as soon as you start her up.
Old Apr 7, 2005 | 08:55 AM
No, there are no cats on the car. Next time I drive it today I will have someone check.
Old Apr 7, 2005 | 11:00 AM
Snrub's Avatar
Another possibilitiy is that your PCV valve/system may not be working correctly. One thing you can do is to try temporarly removing your oil filler cap and see if that relieves the pressure and stops the smoking.
Old Apr 7, 2005 | 01:20 PM
How would that be a cause to smoking? I will also do that before I drive it again.
Old Apr 11, 2005 | 01:06 PM
Snrub's Avatar
Sorry for not responding quickly, I forgot to check the thread after posting the first time.
http://www.fc3spro.com/TECH/PROBLEMS...E/undboost.htm
If the oil pan section is not vented, it will pressurize while the engine is running and cause oil it bypass the turbine piston compression ring seal
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
pzr2
Aug 15, 2015 08:29 PM
