problem with starting, i have to push start at times
Old Apr 5, 2005 | 06:21 PM
DREYKO's Avatar
I "lost" my emissions....
thanks for checking this out anyone who opens this-
my '88 rx7 gxl has trouble cold starting sometimes, like ill walk out to it and it will crank right up every morning but after 3-4 hours ill try again and it acts like its flooded, but i dont press the gas, so after push starting it will crank right up again, i dont know what the problem is, so if anyone can help me its greatly appriciated. also my sunroof wont open the motor in it is going but it wont actually open. any help/tips are greatly appriciated, thx.
dreyko
Old Apr 5, 2005 | 06:35 PM
slpin's Avatar
7th Heaven
to fix your problem...
1. disconnect battery
2. install new engine
*or might be injectors...*
how much miles do you have - do a compression check
Old Apr 5, 2005 | 06:38 PM
SonicRaT's Avatar
Super Raterhater
It probably is flooding. More than likely a combo of low compression/bad plugs/dirty injectors.
Old Apr 5, 2005 | 06:45 PM
tidanb0utch's Avatar
same problem than me . the problem in my case:
injector dont hold gaz
get out injector,and test flow
i rebuilt my 4 injector,and this problem never recome .
cost in my case, 20$ for the test flow
20$ for rebuilding each injector.
Dan
Old Apr 5, 2005 | 07:20 PM
bingoboy's Avatar
Lava Surfer
for the thifties who can't afford down time or injector cleaning, redline fuel system cleaner seams to work pretty well.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
