master cylinder?
Old Apr 5, 2005 | 09:30 AM
unek87's Avatar
NA-BOOSTIN
master cylinder?
can i use a mc thats for non aas if i took my aas out i know some of you guys are going to say search but i'm in a hurry cause i need to order it in a lil while so it can be here tomorrow thanks
Old Apr 5, 2005 | 09:49 AM
xtremeskier97's Avatar
Why not just get the one you are supposed to get?
http://www.nopionline.com/nopistore/...A%20RX7%201987
Unless you dont have ABS..then this one:
But I would assume if you are removing all the AAS equipment, then you could just get the standard one:
Old Apr 5, 2005 | 10:01 AM
Parastie's Avatar
Mountain Rotary Mod
No, the break lines do not match.
IIRC, the non AAS has 4 lines and the AAS has 2 lines...but i could have that mixed up.
Old Apr 5, 2005 | 10:04 AM
unek87's Avatar
NA-BOOSTIN
i'm bout to remove the aas thats why iwas asking cause i need a new master cylinder right now and i saw that the prices change when you dont have abs and aas . one last thing what is the sensor at the bottom of the mc for? not the one on the reservor but at the very bottom thanks again
Old Apr 5, 2005 | 10:05 AM
unek87's Avatar
NA-BOOSTIN
and i dont have abs just have aas thats bout to be removed
