Power FC interface not responding...
Old Mar 30, 2005 | 04:58 AM
subyfiles's Avatar
tearing out my hair! Datalogit guys never respond any of their mails. They have sent me a USB to RS232 cable that I could not install the driver of it. I've tried all the drivers on the cd that they ve sent with no success on WIN98. than I decided to try it on a laptop installed Windows XP still no success. Both OSes can not recognise the device!
Lastly I decided to buy a serial cable with a converter on one side again it says interface not responding! I wish I have never bought this software!
Old Mar 30, 2005 | 11:45 AM
Robertio's Avatar
Win 98 is not USB compliant, second edition made some attempts to support USB, but it is at best hit and miss (so no surprise it didn't work right). It should however work fine under XP.
Have you plugged the datalogit into a normal serial port? best to check the box is working before introducing the converter.
If it does work through the serial port then try using it through the converter on each of the ports (in FCEdit - Setup - Port - Com1..8 ) and see if it picks up on one of the higher port numbers.
I've had the same problems getting replies from Glen & co which cost them sales, but if you keep at it the odds are you will get a reply at some point.
Old Oct 8, 2006 | 06:23 PM
jayjay22's Avatar
this is true my fc box only responds on com port number 3
thanks
Old Oct 9, 2006 | 12:02 AM
fd3s7007's Avatar
i did the same. specify port 3 (if its not used) then i reduced transfer rate to 7200 and voila it works.
DaleClark
Interior / Exterior / Audio
Jan 3, 2005 04:54 PM
trainwreck517
Engine Management Forum
Oct 20, 2004 03:42 AM
Spank
Power FC Forum
Feb 28, 2004 01:38 AM
13brv3
Power FC Forum
23
Feb 25, 2004 08:47 AM
