Ordered 17x8s and 17x9s for the FC
Old Mar 24, 2005 | 11:11 PM
RoadRaceJosh's Avatar
Hobby or mental illness?
Thumbs up Ordered 17x8s and 17x9s for the FC
Ok, I took the plunge and went for the wheels I wanted instead of waiting for some 17x9" F*rd wheels to fall into my lap. I already bought some 17x8" Mustang wheels, but they were a bargain and I can easily get my money out of them. These wheels are supposed to be reasonably light and are actually A-Tech wheels rebranded by America's Tire Co. $112 ea for the 8s and $115 for the 9s. Cheap! What's going to kill most people is the fact that I scored a set of 235/45R17 and 255/40R17 (Supra Turbo OE size) Potenza S-03s with less than 30 days use (customer ride sstisfaction return) for $120. I was in the right place at the right time and helped out a Bridgestone manager with a little internet connectivity problem he was having. So I'll have some good meats for the GTU project. A little fender rolling and we'll be styling! Gotta go put the hurt on the local Porsche club autocrossers!
Old Mar 24, 2005 | 11:29 PM
ARD T2's Avatar
What offsets did you buy? Do you have coilovers?
Old Mar 24, 2005 | 11:40 PM
28mm on the 17x8s and 17mm on the 17x9s as per the FC wheel fitment thread. My only concern at this point is the front tire rubbing the spring perch. I do not have coilovers yet, but if my RS-R race springs don't ship soon I'll be calling Ground Control. I already have KYB AGX dampers on the shelf.
Old Mar 25, 2005 | 12:26 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
it should clear the inners no prob... but... its going to be out over an inch fron a stock TII on the front... post a pic when you get 'em on.
Old Mar 25, 2005 | 02:05 AM
AsianFlip06's Avatar
Slide Or Die
Hey i ordered those rims but the guy called the warehouse and they told me they are back ordered on the 17x9 17offset for nearly 3months. But the color i chose was bronze but maybe they had the gunmetal in stock? Let me know if you get them because my 17x9 27offset is suppose to come in later today. I
Old Mar 25, 2005 | 05:09 AM
RETed's Avatar
9" wide, +17 in the rears will stick out too much!
Hell, a 9" wide, +17 will fit up front!
The 9" wide, +27 is a better fitment in back.
-Ted
Old Mar 25, 2005 | 09:29 AM
Aww, crap. I was relying on this post from the FC wheel fitment thread:
Originally Posted by DigitalSynthesis
Amen brother, about time. Here's what I've learned:
Per RETed:
17" x 8" +27mm offset (+30 to +25 should work) with 225/45/17 up front
17" x 9" +20mm offset (+15 to +30 will work) with 255/40/17 in back
I'm particularly interested in the 5Zigen FN01R-C wheels which I think just match these values.
Note: after further research, I have learned that RETed's wisdom of matching the tire width with the rim width is actually considered a very good theory on handling improvement and is recommended by some guy who wrote some book that I am too lazy to re-research right now. Let's not digress the thread with who it was, but just to say that, yes, it appears to be very solid advice indeed.
So +27 on the rear will fit better. Ok, I'll call the wheel shop and have them change it!
Old Mar 25, 2005 | 10:06 AM
Ok, called America's Tire and changed the rears from 17x9 +17mm to +27mm.
Now I need to get to work on the engine!
Old Mar 25, 2005 | 01:51 PM
jdmluver's Avatar
8.12 @18psi
Hey i wanted to know if size 18x8 front with a 2 inch lip and 18x9 back with a 3 inch lip, with a 38 offset fit on my Fc. I dont have a wide body kit so was wandering if it would stick out or not.
Thanks.
Old Mar 25, 2005 | 03:47 PM
neverenough's Avatar
Thanks.
My 18x8 +38 front with a 225 tire required a 5/16th spacer.Still fits under the fender.
Old Mar 25, 2005 | 05:40 PM
$150FC's Avatar
Currently Winning
I wish you guys would learn how offsets work and do the math yourself, or even read the pages and pages in the "Official FC Offset Thread", instead of cluttering this place with garbage.
Old Mar 25, 2005 | 06:35 PM
dregg100's Avatar
i wish somebody would explain in plain details how offset works, including pictures or what ever you need to make crystal clear.
-masin
Old Mar 25, 2005 | 07:05 PM
fc3s lovin's Avatar
Newbie
-masin
sure
read this offset explanation
then play with this wheel offset calculator
The fc fitment thread rocks, read though it when you get a chance
Old Mar 25, 2005 | 08:14 PM
RETed's Avatar
Yeah, I need to change those numbers a bit since they are kinda outdated.
FD rims are 8" wide, +50, and about the tightest you can go in the rears.
Extrapolating to a 9" wide rim, that shifts the offset to about +37.
Now, this is dependent on tire size (width), so adding 10mm off spacing should be able to handle 255, 265 tires no problem.
-Ted
Old Mar 25, 2005 | 08:17 PM
amishboy's Avatar
90 Turbo
-Ted
Dang Ted you are so knowledgeable .
Old Mar 25, 2005 | 08:18 PM
jdmluver's Avatar
8.12 @18psi
Thanks but i just saw the size i was looking for it took acouple of hours but i got it.
Old Mar 25, 2005 | 09:11 PM
RETed's Avatar
I redid my Rims page to make it a little bit easier to understand.
I also added a rear clearance table...
http://fc3spro.com/TECH/MODS/RT/rims.htm
-Ted
Old Mar 26, 2005 | 06:56 AM
-Ted
Ted,
You rule! Now wish me luck in humbling overpriced German cars amongst the cones.
Old Apr 24, 2005 | 02:44 PM
89fc3sNA's Avatar
did you get your rims yet? i was lookin at those but wasnt sure how they'd fit. post up some pics once you get them on!
Old Apr 25, 2005 | 02:32 PM
owen is fat's Avatar
wow that is cheap!
thats a serious option for autocrossers who wanna run 255's up front and 275's out back!
I might just do that!
thanks man!
Old Apr 25, 2005 | 02:39 PM
-Ted
Ted, you need to correct your 10'' fitments... didnt blackFC on fc3s.org run a 275 wide drag radial on 17x10 5zigens with a +35 offset under stock or lightly rolled fenders?
especially look at the difference in offsets between the 9'' and 10'' size on your chart, there should only be a 12mm difference between the two.
nice of you to provide these guys with info, many thanks.
Old Apr 25, 2005 | 03:03 PM
LT8TurboII's Avatar
Yes I did and still am
Old Apr 26, 2005 | 06:57 AM
RETed's Avatar
Yeah, you're right - those numbers for the 10" wide rears are supposed to be for a 10.5" wide rim. doh!
I need to change the numbers later...
Thanx for catching that!
-Ted
Old Apr 26, 2005 | 01:19 PM
ARD T2's Avatar
We've run 10" +40 with 285/30/18 with stock fenders in rear and about 2 degrees of camber.
Rishie
Old May 9, 2005 | 04:56 PM
I've got the tires mounted and finally got my RS-R race springs. A week ago Sunday I got the dampers and springs changed out. Only the left front damper was doing anything! The other three dampers were so wasted you could move them quite easily the full stroke by hand. I guess this is to be expected from a free 180k mile car.
I test fitted a front wheel and it clears the spring fine, but I may need to roll the fender lip to make sure I have clearance there during suspension compression. Oh, the center cap does not fit! The hub pushed the center cap out as I put the wheel on the hub. This is a racing project so it's not that big a deal to me, but everyone should know if they buy these wheels the center cap won't fit on the front. America's Tire sent me the wrong hub centric rings and I just got the replacements 2 days ago. The car is a project and is currently outside so I didn't mount up more than the one wheel. If you want I can do one side and take some pictures.
