stock boost
Old Dec 23, 2001 | 01:16 PM
new recruit's Avatar
stock boost
just starting mods on my 87 t2. I put a boost and mixture gauge in. Does anybody Know what the boost should be? No mods yet just a k&n inbox filter. I want to make sure it's running right before I start.
Thanks in advance
Old Dec 23, 2001 | 01:29 PM
Scott 89t2's Avatar
SOLD THE RX-7!
stock on an 87 is 5 to 5.5psi
Old Dec 23, 2001 | 01:51 PM
Thanks , I only get 4 psi I wonder if I have a leak in the Gauge line. Just to cross referance what should the stock gauge read?
Old Dec 23, 2001 | 02:00 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no idea about the stock gauge. I wouldn't even bother to try and read it. you get 4psi in every gear? is it an autometer boost gauge?...
your cats are probably clogged a bit.
Old Dec 23, 2001 | 02:03 PM
Brian P's Avatar
Thats probably about right if you don't have any mods, your exhaust is probably partially clogged and without a freeflow intake/exhaust thats what you're going to see on a completely stock car.
Fuel cut I belive is about 8.6psi, just putting an exhaust on can get you into fuel cut territory, then your will need an FCD. Just do a search for FCD and there is alot of information on what it does and what other things you have to do when you use it (fuel upgrades)
Old Dec 23, 2001 | 02:23 PM
I was thinking for next year when I bring it back out of putting a down pipe in and getting the computer reprogramed. I want to be safe, I don't want to blow it. With the computer done will I still need a fcd? Is it worth getting done?
Jim
Old Dec 23, 2001 | 02:26 PM
It is an autometer gauge.
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
TerryD
Aug 23, 2015 07:40 AM
