Smoking out When Starting UP
Old Dec 22, 2001 | 10:56 PM
Prowla RX7's Avatar
It's Whatever
After my car has sat for a certain amount of time... say when it goes to the 3k idle, i notice that when i go to start it up white smoke comes out from my exhaust... what could be causing this problem? I tried to do a search, but it yielded nothing.. Please help me thanks
Old Dec 22, 2001 | 11:01 PM
MisterMatt's Avatar
Smoke at startup is perfectly normal. It's probably just a little oil smoke. Something that has to be put up with. You'll get used to it soon enough!
Old Dec 23, 2001 | 01:15 PM
Prowla RX7's Avatar
It's Whatever
oh im already used to it, just wondering if there was anything causing it that i could fix
Old Dec 23, 2001 | 01:37 PM
fLyiNgOuFeR's Avatar
you should try "STP oil treatment" it comes in a blue bottle and is about as thick as maple syrup. you add it to your oil every oil change.( takes HELLA long to get all that **** out of the bottle) it helps a little for the engines that are a little old and smokey. hope this helps
1987 T2
11
Apr 1, 2017 11:59 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
gabescanlon
Sep 5, 2015 12:09 AM
