power antenna doesnt work.
Old Dec 22, 2001 | 04:11 PM
Yelow RX-7's Avatar
Swingline Stapler
my power antenna doesnt work. theres no motor sound or nothin. and when i turn my stereo on, i cant get any channels in the fm. i used to be able to but now i cant. could it be that the antenna wire fell out of the back of my head unit? please help me.
Old Dec 22, 2001 | 04:56 PM
vaughnc's Avatar
knowledge junkie
The antenna wire plugs into the power antenna and the back of the stereo. So long as the actual antenna is still around you should get reception.
I paid $90 and change it myself. THe OEM mazda one is a bit more, but you don't have to widen the bolt holes as with the aftermarket one.
Old Dec 22, 2001 | 05:33 PM
LLADNAR's Avatar
mine doesn't go up and down. do the base models have a solid antena,,i would like to have just a solid mast antena.
Old Dec 22, 2001 | 05:43 PM
vaughnc's Avatar
knowledge junkie
You could get one of those rubber sport antennas and it would look good.
Old Dec 22, 2001 | 05:51 PM
chris_stampe's Avatar
If i were you I would just get an antenna that fits into the body (pretty cheap on ebay) I think it looks better that way, and its less expensive that trying to fix a power ant. Anyways, I love you car, it looks alot like mine except mine is red with gay factory rims. I was trying to decide on white or aluminum, but I think looking at your car has made up my mind. Good luck with the antenna
Old Dec 22, 2001 | 05:58 PM
Erik's Avatar
Best of both worlds
Re: power antenna doesnt work.
check out the junkyards...the antenna on my n/a didn't work when i got it. then i got one from the junkyard and slapped it in...
streetlegal?
Mar 17, 2022 02:46 PM
andyvideopro
Aug 11, 2015 09:16 PM
