I have problem with lag.... plz answer !!!
Old Mar 15, 2005 | 09:09 PM
BlueSprite's Avatar
Currently, i have a rebuilt engine with Race Port and T78 setup, but the car is running very rough and no power (lag); and it is very hard to drive. Does anyone know the problem ?? or what can i do ??
I have Power FC too.
Old Mar 15, 2005 | 10:15 PM
Trexthe3rd's Avatar
Start with a compression check. Follow that with ignition system inspection, then fuel system. If they all check out, your PFC is either not working or not setup correctly.
With a race port, your car will idle like crap drive like crap at low engine speeds.
Old Mar 16, 2005 | 01:07 AM
BlueSprite's Avatar
I checked all of them, there are function well. I m thinking about the PFC because i m new user of PFC and the PFC has not been tune yet. In low speed, it is a crap.
Do you know how i can fix it ??? dyno tune ?? or sth else ??
Old Mar 16, 2005 | 01:27 AM
Pressurized's Avatar
if you have all that done and don't have your PowerFC tuned yet, then your priorities are mixed up. it would be safe to not drive the car until you can get it on a dyno and tune it or get a map from someone with a similar setup. the problem probably is the PowerFC, you probably have all the wrong timing and fuel settings...whether that fixes the problem or not, it's still something that should be priority #1...you could end up with a blown motor very easily if that's the case.
Old Mar 16, 2005 | 07:18 AM
Jack's Avatar
Check to see if your map sensor is connected.
Old Mar 16, 2005 | 09:59 AM
IAN's Avatar
IAN
Rotary Reborn!
I can't offer much info on this except I have the same problem. Lots of lag and little boost on a new T04B turbo. Turbo seems fine.
Check to see if the turbo spins freely. I was told that if the turbo spins freely then you can eliminate this.
The only thing I can think of is that you have a boost leak. But I still would assume you would here the turbo spin like crazy to provide boost?
Ian
P.S. Also make sure the boost sensor (Map sensor ) is hooked up right. I had it hooked up wrong during some trouble shooting and the car idle really bad and no power. I connected it to the wrong nipple on the UIM.
Old Mar 16, 2005 | 07:43 PM
BlueSprite's Avatar
i m appreciated for all your reply. My built engine is just built and it hasn't pass the break-in period yet; and i would like to do dyno tune after the break-in. In this case, What should i do ??
I test drive the car again, it has no power and hesitation under 3500 (I mean the car is very lag) Is just hard to drive. Also, it has a lot of smell of fuel coming out from the exhaust, will that be the Map Sensor problem or the ECU (un-tuned)
BTW: i removed the cold-start sysytem, and the car is very hard to start up even in hot condition ( it needs to crack so many time, i think about 7-8 crack to start the car)
Old Mar 16, 2005 | 08:55 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
did you change your fuel injectors?
i'd say get to a tuner and at least tune the low throttle (vacuum) areas. that should make it run worlds better.
if it ran fine before the porting and everything else is the same, you're probably running way too lean.
Old Mar 16, 2005 | 10:57 PM
BlueSprite's Avatar
I didn't change the fuel injectors, but i did clean and port the fuel injectors.
Clean the Primary, Clean and port to 1300cc in secondary
You mean i m running too lean ??
Old Mar 16, 2005 | 11:09 PM
sonnguyenrx7's Avatar
you are in norcal if you have time just come to rotaryextreme shop and Chuk can check it out for you
Old Mar 16, 2005 | 11:42 PM
BlueSprite's Avatar
but i don't know i can drive up that far. I m in SF.
My car just got engine rebuilt, and i m waiting for the break-in period over before i go dyno.
And the car just running like crap in low idle, it maybe the fuel and the ECU (non-tuned)
Old Mar 17, 2005 | 01:11 AM
definately sounds like a tuning problem.
you can have it partially tuned without flogging it.
Old Mar 17, 2005 | 11:58 PM
BlueSprite's Avatar
so what do i need to do ???
check the timing ?? btw: how can i adjust the timing ?
Old Mar 19, 2005 | 09:43 AM
just get it tuned.
Old Mar 19, 2005 | 11:54 AM
BlueSprite's Avatar
do you mean dyno tune ???
can i use PowerFC to adjust the timing ???
Old Mar 19, 2005 | 12:11 PM
you can if you know about tuning, but there's a lot to it. if you've never done it before, it would be best to take it to a shop that tunes pfc's.
Old Mar 19, 2005 | 12:24 PM
MazdaSpeed93's Avatar
Sounds like you're too rich down low.
Edit - Nevermind what else I just said, just have a shop do it lol.
-GST
Old Mar 19, 2005 | 05:33 PM
if none of the settings were changed, it's probably too lean because of the port job.
Old Mar 21, 2005 | 02:54 PM
BlueSprite's Avatar
Yes, it is too rich, but i cant adjust to ordinary; because the car will turn off when i stop. So that my friend set it too rich. Is it any method i can fix it to ordinary without any running too rich.
I have 550cc primary and 1300cc secondary, and stock fuel rail and FPR.
BTW: I remove the cold start system. And i would like to know anyone has problem when they start up the car even in warm condition ?? cuz my car is hardly start up in hot condition.
sin
Old Mar 21, 2005 | 03:34 PM
wht makes you think it's running too rich?
Old Mar 21, 2005 | 07:12 PM
BlueSprite's Avatar
my frd set it up for me.... if we drop down the fuel supply the car will run ok in idle, but it will die when stop (too lean also)
I m thinking there is some timing i need to reset, right ??
Old Mar 21, 2005 | 08:57 PM
i think you just need to have it tuned.
Old Mar 22, 2005 | 10:11 PM
widebody2's Avatar
addicted to lounge
A good sign its running rich is that smell of fuel comming out of the exhaust...the injectors are probably absolutely dumping gas right now and thats why the car is running like crap. I had the same situation with the car running insanely rich and the fuel smell....you can probably shoot a really impressive flame right now at least haha. You need to get the car somewhere where they can just give you a better base map so you can get the breakin period done. You also shouldn't be worrying about lag right now because you shouldn't know the turbo is laggy...don't boost w/o having the car tuned for christ's sake. This sounds like you are asking to buy another new motor.
Aboout the cold start, did you wire the thermowax up? as in trick the car into thinking it is actually warm when its not? If you didn't the car will run like crap for that reason too.
Old Mar 24, 2005 | 04:16 PM
turboand's Avatar
...from sunny Mancunia
The PFC base map will START AND RUN a STANDARD car, basically so you can drive carefully to your tuner. With major mods, the standard PFC map will struggle to do that, you should trailer it to your tuner and get a base map suitable for your car to run it in. At the very least get an ACCURATE A/F meter in there to monitor your part throttle driving and keep a VERY close watch on your knock level in the PFC.
Old Mar 26, 2005 | 01:08 PM
BlueSprite's Avatar
Where can i get a base map, so that i can pass the break-in period ??
