1st gen. guru's, i got a ? for ya....
Old Dec 20, 2001 | 01:48 PM
Grimlock's Avatar
Question 1st gen. guru's, i got a ? for ya....
my buddy has a 84 rex. he got a 4 port motor put in it with carb. set up. now he's thinking of getting a fuel injection set up.
whats the easiest way to approach this and how.
any help or direction would be greatly appreciated?????
Old Dec 20, 2001 | 01:55 PM
zyounker's Avatar
root
Well, what type of carbs does he have? if the carb is a Webber he can just buy a TD that will sit ontop the intake manifold.. then buy injectors and a fuel computer....
http://www.twminduction.com/
These guys sell Webber style TBs that you can use..
For the computer you could do something like a Haltech F9.. And for injectors pick up some injectors off http://www.thepartstrader.com they should work...
I would probably do 2 550cc injectors.. Maybe 4.. anyone got a fuel calc?
-Zach
Old Dec 20, 2001 | 01:56 PM
zyounker's Avatar
root
He will also need a fuel pump & regulator..
-Zach
Old Dec 20, 2001 | 02:22 PM
Grimlock's Avatar
thanks dude...
but he has a 650 cfm holley. any other ways of doing efi????
Old Dec 20, 2001 | 02:24 PM
zyounker's Avatar
root
You can buy a square flange TB just the same.. do a search on google for one.. BTW you should be looking for a 500-600CFM...
-Zach
Old Dec 20, 2001 | 03:58 PM
Grimlock's Avatar
thanks again....
yeah i know i told him 450cfm actually but he has a street port so racing beat says he should get a 550cfm.
so a throttle body and fuel computer.
so it would go somewhat like this:
throttle body replacing carb. then put 4 injectors (TII 550's) plummed into tb. am i right on this so far because i dont have a clue really. and a f9 haltech replacing his stock ecu.
how much you think this will run?
thanks again....
Old Dec 21, 2001 | 08:28 AM
zyounker's Avatar
root
Well, the f9 is about $1K so it is pretty expensive...
But you can watch the partstrader for used ones..
Also there is a company called SDS that might have something you could use.. Or there is the wolf 2d....
Everything you had there looked good..
A TB usually will cost you ~$300-400
BTW is his motor a 12a????
-Zach
Old Dec 21, 2001 | 10:00 AM
Grimlock's Avatar
its a 13b 4 port rebuild with a street port.
Old Dec 21, 2001 | 10:04 AM
zyounker's Avatar
root
In that case if you are low on money pick up a 13B manifold & TB.. Then pull off all of the crap & put some block off plates on it.. port it as you like & run that... then all you would need is the computer...
You can use the manifold from a TII, that would be the cheapest.. I know someone who has the TB & upper manifold off of a 90TII that he'd probably sell you..
his email is kurgan@darkcloud.org tell him i sent you..
-Zach
