Steering Column
Old Mar 3, 2005 | 12:53 AM
RussinStk's Avatar
Auto-X Junkie
Steering Column
For those racers out there...
I want to replace my current stripped stock steering column (shaft) with standard race shaft.
Is there a source for direct replacement? What are you EP guys doing for a steering column?
Thanks
Old Mar 3, 2005 | 03:24 AM
SPiN Racing's Avatar
On my EP 7.. that is still getting all the parts pulled together..
I am planning on using a tilt column from a TII/GXL.
Main reason for this is to be able to put the wheel where I want it with the seat sitting on the floor. Also if I have a co-driver for anything it adds a bit of flexibility.
IF... IF I need to save weight.. I will go with the standard shaft from coleman with joints on it for collapse.. and a Heim joint off the cage to hang it.
http://www.colemanracing.com/catalog...ca99a886c98597
If you cant piece together a steering system from there.. you must not have a good net connection or something..
Old Mar 3, 2005 | 05:46 PM
jgrewe's Avatar
GET OFF MY LAWN
Ditto
