making a 13bt run by its self
Old Mar 2, 2005 | 01:11 AM
cjbechtel's Avatar
i have been looking into what would be required to make a 13bt run on its own for a swap into an older car. no smog would be required. if a standalone is used what is required? and what if the stock computer was used, or is that even possible? i know a lot about the components of the 13bt but i dont know much about standalone computers. the motor would be out of an 88. thanks guys.
Old Mar 2, 2005 | 05:31 AM
kenn_chan's Avatar
Savanna Rx-7
Wink
Interesting question, suggest you post it in the 2nd gen forum though, they would be able to help you.
Ken
Old Mar 2, 2005 | 09:43 AM
13btnos's Avatar
I had a 1973 RX3 with an 87-88 13BT motor in it. It was completely stock. Stock block and transmission and stock computer. Car ran great I drove it around for over 3 years as a daily driver then sold it to a friend who still drives it. Pretty simple setup really all you need is a complete motor and transmission. The ecu with a complete wiring harness, basically the whole wiring loom that attaches to the ecu. Which would include all the sensor, ignition system and injection system. I even used the ignition switch from the turbo car so basically I had two separate wiring harnesses in my car the factor for all the lights and the turbo harness for the motor. On the motor you have to change to front engine mount from a 84-85 gslse 13b and also need the oil pan from the same year rx. And you need to fab a custom driveshaft the splines on the turbo trans are different than the n/a rx7 driveshafts. That's about it. It's alot of work but not impossible. Hope this helps and good luck.
Old Mar 2, 2005 | 10:04 AM
cjbechtel's Avatar
sounds good. the rough plan is to put the motor in an old datsun 1600. my rx7 was stolen and recovered in pretty bad shape. The motor only had 2000 miles on it. if the motor isnt destroyed i wan to transplant it into something unique.
Old Mar 2, 2005 | 10:45 AM
cjbechtel's Avatar
i should reword my question some, i want to know the minimun i would need to make the motor run. what sensors and systems i can get away with removing. im going to link this to the secong gen forum also. i though you guys woud know this info from doing swaps into different cars. thanks.
Old Mar 2, 2005 | 10:53 AM
RexRyder's Avatar
everything except for the smog stuff.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Rotospectre
Mar 28, 2018 03:33 PM
Machupicchu
Aug 17, 2015 08:27 PM
