What size tires would you run?
Old Feb 22, 2005 | 10:57 PM
Nick86's Avatar
Yup, still here
After doing some searches, I've found some contradictory opinions regarding tire size for aftermarket wheels.
If you had my setup - what size tire would YOU run?
Car:
1986 Rx7 GXL
Suspension:
RB springs, Tociko blues
Wheels:
17x7 +33 Front
17x8 +36 Rear
What size tires can I use, and what size tires should I use?
Thanks!
Old Feb 23, 2005 | 04:17 AM
RETed's Avatar
225/45/17
If the car is making significant power, I'd step up to a 255/40/17 in the rears, but I doubt your NA can make over 300hp at the wheels.
-Ted
Old Feb 23, 2005 | 07:23 AM
ptrhahn's Avatar
I'd go w/ a 225/45/17, 245/40/17 combo with those rim widths.
Old Feb 23, 2005 | 07:41 AM
Nick86's Avatar
Yup, still here
Originally Posted by RETed
225/45/17
-Ted
No, 300 at the Flywheel.
Seriously though...
Would 225's fit alright upfront? I was under the impression that on a 7" wheel you should be running a 215/45/17.
Yeah, 255's would be overkill.
Old Feb 23, 2005 | 10:16 AM
owen is fat's Avatar
I'd agree.
Old Feb 23, 2005 | 02:15 PM
RETed's Avatar
Forgot about the 245/40/17...
http://fc3spro.com/TECH/MODS/RT/tires.htm
I made that chart to give you comparative rolling circuferences versus stock Turbo II tires.
225/45/17 on a 17" x 7" is fine.
-Ted
Old Feb 23, 2005 | 02:54 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Check out Teds site its a good place to start and you can get a real idea of what the tires are doing as the size and aspect ration changes..
keep in mind those numbers are averages for that general tire.. either go to tire rack and pull up the size and make of tire you want and then hit "Specs" or go to the manufactures website to get the actual numbers.
However... in general... 225/45/17s should be just inside the outer edge of the fenders and be about the same as stock on the inside with that offest.. you may get some tire rub on the fender lip if you hit a bump real hard, dunno.. but it should pass inspection !!!!!!!!
Old Feb 23, 2005 | 03:00 PM
Nick86's Avatar
Yup, still here
That said, would it be better to go with a 215 up front and a 225 in the back? What is the chance that I'll get fender rub? I'm assuming that you are talking about the fronts only - right?
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
