removing waterpump housing
Old Feb 20, 2005 | 03:33 PM
NSBerkland's Avatar
Okay so I am getting ready to remove my waterpump housing to replace it (I snapped a bolt off in the filler neck and failed at drilling it out) So I was wondering when i put everything back together should I put some sort of grease on all the threads to prevent any rust like anti seize or something? Also on the housing to block gasket should I put a lil bit of gasket sealer on each side?
Old Feb 20, 2005 | 05:00 PM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
a little bit of anit sieze couldnt hurt
i use 3m wetherstrip adhesive (yellow) on the gasket an apply it to housiing . then i put some rtv on the other side of the gasket.
cdn
14
Sep 10, 2015 06:23 AM
rotor_veux
Aug 31, 2015 07:49 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
