t04e HP question
Old Feb 20, 2005 | 02:24 PM
Travelintrevor's Avatar
B.G.O.B.G.A.I.
t04e HP question
How much HP can a T04E (not a hybrid) with Comp .60 57T, P-trim and ex:A/R 0.70 make? Is the hotside to small for about 350rwhp??
Old Feb 20, 2005 | 03:13 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
go with the .70 a/r comp and the 1.15 a/r divided p trim ex....it'll make 400.... .70 a/r ex is way to small...Max
Old Feb 20, 2005 | 04:45 PM
ghostrx7's Avatar
hmm...t04e...barely an upgrade over stock..id try something larger...
Old Feb 20, 2005 | 04:49 PM
r1dreamer's Avatar
well with steve kan tuning my t04e on a stock ported motor iwth my exhuast going from 3in to 2-1/2 back to 3inch and no intake filter, on 10psi i made 303 to the wheels. i might be selling my xs-engineering turbo cuase i just bought a t04s. hope this helps.
Old Feb 20, 2005 | 04:52 PM
B.G.O.B.G.A.I.
amazing...look at this list..they make 400+ with less than what you are saying
http://www.sol.co.uk/h/hugh/HKS%20Turbo%20Model.mht
the turbo I asked about make 500 horsies
http://hksusa.com/products/?id=823&rsku=0
who do i belive?
Old Feb 20, 2005 | 05:20 PM
B.G.O.B.G.A.I.
this thread does not want to update..WTF??
Old Feb 20, 2005 | 05:25 PM
Maxthe7man's Avatar
It'll never make 500 on a rotary , I ran one of these it was a ford truck variant that was a 57/60 mix, they are good to about 400, on ported motor they start dropping boost when running high teens...Its a good turbo for the 375 to 400 range, even on stock ports.. I have a sheet somewhere of my old setup with stock ports, making 365 rwhp on a mustang dyno untuned only pulling to 6300 or so... Running a large exhaust side really helps..
At 10lbs/min per 100 hp, look where 500 would be...
I still have this turbo sitting on my tool chest..
Old Feb 20, 2005 | 10:32 PM
ghostrx7's Avatar
A few local guys are using them...they are nice street turbos, but one made 358@14 lbs...Id stick with something larger if you are looking for good #s...
Old Feb 21, 2005 | 04:01 AM
B.G.O.B.G.A.I.
thanks..350-380rwhp is plenty for my vert..and the spool up will be quick
Old Feb 21, 2005 | 11:39 AM
Mills's Avatar
procrastination engineer
That's what I thought at first. Then I got the disease and bought a T04R with a small hotside. It should make more power at lower boost levels and has plenty of room to grow .
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
