OE FOG LIGHTS need help bad im stumped
Old Feb 19, 2005 | 02:11 PM
sleejay's Avatar
omae mo na!
ok my 89 gtu never had fogs. from the factory, no fogs.
SO what i did was i got a pair of stock fogs with brackets and wiring from a member on here.
then i went to the junkyard and got the switch (that goes next to the alarm light)
my car HAS the plugs for the fog lights, and the switch plugged in just fine, but they dont turn on even with the low beams on... is there something else i have to do? if i give the lights direct power from the battery they light up no problem. am i missing something here? the fuse is in and is fine
thanks
Old Feb 19, 2005 | 02:40 PM
KNONFS's Avatar
B O R I C U A
thanks
You are missing the realy!
If you stand in front of the car while the hood is open, the coolant overflow tank will be to tje left, front of you. Perpendicular to it, to the right, there will be three or four relays (can't remeber the right amount), bolted to a piece of metal of the body shell, there sould be an unused plug, that's the fog light relay
Old Feb 19, 2005 | 02:41 PM
sleejay's Avatar
omae mo na!
do you know anywhere i can get it? what does it look like? where does it go? does it go up front by the headlight relay? got a pic?
i want to get this done! :P
Old Feb 19, 2005 | 02:44 PM
KNONFS's Avatar
B O R I C U A
Check my post, I edited it
Old Feb 19, 2005 | 02:50 PM
sleejay's Avatar
omae mo na!
what part # is it? is it the same as a headlight relay?
the other relays have #s on them, H# will this one be numbered so i know which one to pull from the yard?
Old Feb 19, 2005 | 02:52 PM
KNONFS's Avatar
B O R I C U A
You got me there, I used a bosch 5 pin relay; however I believe they are all different (the plug that is). On my 91, the foq light relay plug was green.
Queppa
Nov 18, 2024 03:47 AM
