Good tires to wrap 15" BBS Vert Stockers??
Old Feb 17, 2005 | 11:20 AM
STR8BALLIN - R's Avatar
I'm in the market for new tires and am thinking I want to upgrade a bit to something more performance oriented.
Can people give me some ideas of what will fit and what's good for that wheel size...the car is bone stock, no suspension mods..nada/
thanks
Old Feb 17, 2005 | 01:58 PM
adam c's Avatar
Cheap Bastard
http://www.ec-securehost.com/OnlineT...Toyo_T1-S.html
How wide are your wheels?
My rules of thumb:
7" rim = 205 tires
8" rim = 225 tires
9" rim = 245 tires
Old Feb 17, 2005 | 04:47 PM
snub disphenoid's Avatar
My rules of thumb:
7" rim = 205 tires
8" rim = 225 tires
9" rim = 245 tires
How wide of a tire you fit on a wheel is also somewhat dependent on the sidewall. You can run up to a 275 on a 9" wide wheel without any real issues.
Old Feb 17, 2005 | 06:57 PM
adam c's Avatar
Cheap Bastard
Sorry snub, I disagree. Although you may be able to mount 275 tires on a 9" wheel, it is far from ideal, and handling will suffer. A 10" rim would be a better choice. The sizes I listed are pretty close to ideal for the tires listed. Some deviation is OK, but any more than 20 mm wider than the tire size listed would not be recommended.
As an example: A stock FD rim is 16 X 8. An ideal tire size is 225/50/16. Many FD owners go to a 245/45/16. This tire would work better with a 9" rim, but many owners don't want to buy new rims.
Old Feb 17, 2005 | 07:57 PM
FCdemon's Avatar
3rd gen junkie
falken azenis sport. cheap and they have the perfect size for you
Old Feb 17, 2005 | 11:26 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I had some dunlop sSP5000's on my GTU and I liked the hell out of them
205-60-15 is stock for your car, tireracks got 'em for 75 bucks each. Handled good, good traction for the price
If you want to go a bit wider you can run 215-65-15's on there, but they are also a bit taller so your speedo will be a few mPH low (not much)
BF goodrich T/A KDW in 215/50/15.. is good, but 112bucks
the also make a g-force sport in 205-60-15.. my buddy has a set of those and they seem to be pretty nice for a stocker sized tire... especially at 65 buck a tire
Unfortunately.. a lot of your really high performance tires don't come in sizes to fit those wheels.
No experience with the falkens.. but the look pretty slick and at 49 bucks.. wo hoooo!!
Old Feb 19, 2005 | 02:07 PM
Bump
any more opinions.........thinking of picking something up at ther car show in toronto...what else shlould i look at?
Old Feb 19, 2005 | 02:28 PM
b00b's Avatar
is it ok to run a 205/50/15 on the stock 15s? or even a 205/55/15?
Old Feb 20, 2005 | 10:38 PM
gnx7's Avatar
TOns of AutoX and roadrace guys put 225's on the 15x6.5" BBS vert rim. I think since you are 100% stock some 205's would be fine and also a tad lighter.
If you want a really sticky tire look at the Toyo RA-1's. It is an R- compound tire and will only last about 10K miles if that. The T1-S from Toyo is not as soft as the RA-1 and is a good street tire and well priced also. Bridgestone S-03's are great and good in the rain. Kinda pricey.
Look on Tirerack.com and compare some of the tires. It shows their wet/dry traction, how long they should last, and other factors.
Some new springs/shocks would really wake your handling up.... How many miles are on the ones you have now?
Good luck,
Mark
Old Feb 23, 2005 | 09:35 PM
trent1059's Avatar
bone stock vert
I just put yokahama es 100 size 215/60/15 on my vert , Love the tires, very nice ride and sticky even in todays light rain.
