Brake help, no air in the lines, but no pedal.
Old Feb 14, 2005 | 03:46 AM
O 16581 72452 5's Avatar
The infamous number guy!
I've asked numberous people about this, i've had friends over saying i was an idiot and didn't know what i was doing, they tried and the results were the same.
This is on my Civic, i posted on ClubSi and haven't had any replies, maybe someone here knows what is going on.
I removed my calipers to paint due to the previous owner painting them white, i reinstalled and tried bleeding them front only (drum in the rear), no pedal, i then tried bleeding the back, still no pedal. I then tried like how it's supposed to be done, right rear, left front, left rear, right front, still no pedal.
When i pump the pedal it holds pressure fine, when i let off and let it sit for a few seconds, the pedal is completely gone. At one point when i bled them, i had pedal, but it required pressing the pedal to the floor until it stopped.
Help!
Old Feb 14, 2005 | 07:03 AM
DamonB's Avatar
Are the calipers on right side up? I've seen people mix the left and right after they removed them and this leaves the bleed screw on the bottom. Bleed screw has to be at the top to let the air out.
If you removed all the calipers and the brake reservoir ran dry because you didn't plug the lines then you have air trapped in the master cylinder that regular bleeding won't remove. Sounds like you may need to bench bleed the master cylinder.
Old Feb 14, 2005 | 03:51 PM
I think you're right, i must've installed them backwards!
Thanks, i will fix them this week and post the results.
Old Feb 15, 2005 | 07:04 PM
Success!
Here is a video to film this joyous occasion, pardon the car running like trash and the *** camera man, the chip is a bad burn.
The audio is terrible in both of these after i uploaded them, the origionals sounded fine.
http://www.putfile.com/media.php?n=20050215_194331
Here is a bonus video of a friend's Mustang.
http://www.putfile.com/media.php?n=20050215_194233
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
