Boost sensor check valve.. air both ways?
Old Feb 9, 2005 | 01:48 AM
jeremyb's Avatar
Hi....
Ok, the hose going from the UIM to the boost sensor has a check valve. The arrow is pointing toward the UIM. Is this right? Shouldn't the chceck valve arrow be pointing the boost sensor? Also, I removed it and blew through the nipples on both sides of the valve. Is it right to have air being allowed to be blown through both sides? I can blow air through both sides. Isn't this supposed to be a one way check valve?
1. Which way is the check valve supposed to point? UIM or boost sensor?
2. Is this a one way check valve? I can blow right through the valve through both ends.
Thanks in advance.
Jeremy
Old Feb 9, 2005 | 02:19 AM
Speed of light's Avatar
Form follows function
That's not a check valve, it's a gas filter designed to protect the boost sensor. Therefore, you should detect flow in both directions. The arrow should point toward the UIM, according to the FSM.
A check valve, by definition, is a one way device. A boost sensor would not function properly with a check valve in the line.
Old Feb 9, 2005 | 11:06 AM
jeremyb's Avatar
Hi....
Ok thanks speed of light, you answered all my questions. I was scared for a minute that i need a new "check valve" but I'm ok now . Thanks again
Jeremy
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
