13BREW with TurboII transmission?
Old Feb 8, 2005 | 11:40 AM
13btnos's Avatar
I have a 1993 13BREW motor that I'm mating to a 1988 TurboII transmission. My question is can you use the TurboII pressure plate with the 13BREW flywheel and will the starter work with the 13BREW flywheel? The clutch disc is the same for the turbo motors 87-95 Turbo I'm using 6 puck solid disc. Now the 13BREW pressure plate is different than the TurboII it is a "PULL" type as opposed to the TurboII which is a "PUSH" type. Or do I have to use the TurboII flywheel to make this work? Any info will be much appreciated.
Old Feb 15, 2005 | 03:29 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I'm not sure if the FC PP wil mate to the FD flywheel.. somehow i don't think so..
But if it doesn't.... the good news is that s5 and s6 engine internals are the same.. .SO all you have to do to make it work is use an s5TII flywheel and PP and then you will have no problems mating the starter and the tranny
Old Mar 1, 2005 | 03:33 PM
beater1.3liter's Avatar
from what I understand one is a push style clutch and the other is a pull. I dunno
Old Mar 1, 2005 | 04:56 PM
680RWHP12A's Avatar
in orded to fit the turbo 2 tranny to the cosmo motor you need to convert to a 255mm push type clutch/flywheel system...
get a clutch /flywheel setup for a turbo 2 motor and use the cosmo engine counterweight and you will be fine
Old Mar 8, 2005 | 07:02 PM
JDuncan's Avatar
Turbo II pressure plates bolt right up to the FD flywheel. Turbo II starter engages the FD flywheel without any problem through the Turbo II tranny.
As for the push/pull configuration of the clutch, the TII tranny only offers the push type engagement which works only with the TII pressure plate. Use your TII clutch slave cylinder and you are good to go. This is how it sits in my car currently.
Old Mar 10, 2005 | 08:24 AM
arghx's Avatar
rotorhead
isn't the TII tranny weaker than the FD tranny?
Old Mar 10, 2005 | 07:13 PM
chris_stampe's Avatar
A bit. or so I have heard.
Old Mar 12, 2005 | 02:30 PM
JDuncan's Avatar
But it is much harder to adapt the FD tranny to the FC chassis than it is to adapt the FC tranny to the FD motor... We don't have a PPF and there is no easy way to remedy that. I would assume that this is what he is doing, since I doubt anyone would be wanting the FC tranny in their FD.
Old Apr 13, 2005 | 03:59 PM
13btnos's Avatar
This is an old post but I haven't had time to check up on. No it's not going into a FC rather a 1971 Datsun B110 1200.
Old Apr 13, 2005 | 05:10 PM
Evil Aviator's Avatar
Rotorhead
No, they are both rib case transmissions, and they are lumped into the same category according to Mazda Motorsports.
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
