Sponsored by: CARiD
rebuild or sctrach
Old Jan 26, 2005 | 02:29 PM
Rip's Avatar
Rip
rebuild or sctrach
is it easier or even cheaper to just rebuild an engine or to start from sctrach and build up?
Plans would be a 13b with approx 300hp. Not to sure about the specifics, but figured 300 can be hit pretty easy, right?
thanks
rip
Old Jan 26, 2005 | 02:43 PM
PhatManBUD's Avatar
cheaper too rebuild, that way you dont have to buy the front, intermediate and rear housings. and also each rotor housing is around 500 a piece. then you have to buy rotors and all the seals, youre already looking at 2,000+
most rebuild kits cost around 800-900. and it comes with everything you need to rebuild your motor and gaskets, and hopefully youd only have to replace 1 rotor housing if you blew a seal and it scratched up the housing, and so you could have a rebuilt motor if you do it yourself for under 1,500.
I dont know if this is the most reliable advice, but its mine, you should see what the other forum members say
Old Jan 26, 2005 | 02:44 PM
PhatManBUD's Avatar
300 hp is easy
Old Jan 27, 2005 | 02:14 PM
Rip's Avatar
Rip
thanks,
was also thinking does a company sell a stock rebuilt motor? I don't have a 13B to start from; or are the off the shelf rebuilds not that great, and one would be better to do it himself.
I'm mechanically incline, but havn't messed with a rotary yet, I figured pick up a few rebuild videos and see if I can do it, probably can, not too worried about it.
just wondering can I buy it rebuilt or find a core and rebuild it myself?
thanks again
rip
Old Jan 27, 2005 | 02:53 PM
813KR$'s Avatar
TEAM MAZDA
Try to find a cheap engine and go from there, unless you got it like that, then just buy one built?
Old Jan 29, 2005 | 07:23 PM
Rip's Avatar
Rip
Thanks for the replies I appreciate it. So... would it be easier to find parts for a 12a or a 13b?
Given the 300hp cap off, is this attainable with the 12a, I'm figuring yes. Then what would be a good reason to use the 13b?
Is a 13b easier to find parts for? Aftermarket? Turbo?
Does $400-500 seem reasonable for a used 12a or 13b?
thanks again for the help.
rip
Old Jan 30, 2005 | 10:49 AM
Lightbulb
rip
what car is this going in? No 12A, go 13B if you want 300 rwhp. Starting from scratch is going to be extremely expensive. Buy a junk motor and send it to Mazda as a core......Ray at Malloy Mazda has the best prices around (1888-533-3400). Remans are now up to 2500ish dollars.
The best thing you can do is buy a blown motor FD (there are a few out there, hehe) and begin your project.
Vartok
16
Oct 8, 2015 04:49 PM
NickNac113
13
Oct 1, 2015 09:25 PM
musker
Oct 1, 2015 05:58 PM
