sa manual into rx4 auto
Old Jan 18, 2005 | 12:39 AM
xrotaryguy's Avatar
Old Car Preservationist
I have a 75 Rx4 sedan and dispite my wanting to keep it all original it is just too boring to keep the way it is with the automatic. I hear that the SA tranny pretty much fits. I think I still have a flywheel from a 76 4 port 13b motor lying around. I'll need a new clutch. I will also need a pedal cluster. Is it all that hard to make an SA pedal cluster fit? Also... was there any difference between the counter weights between 75 and 76. Like I said I would like to use this fly wheel from the 76 so I need to make sure its going to be the same. Any help would be... well... helpfull lol.
Thanks,
Brian
Old Jan 25, 2005 | 10:59 PM
xrotaryguy's Avatar
bump
Old Jan 25, 2005 | 11:56 PM
Magnus Berglund's Avatar
I know that the pre 80 (I think, manybe 81) gearboxes have a different location of the leaver.
Why don't you try to find pedals from a 929? They should fit.
//magnus
Old Jan 26, 2005 | 07:11 AM
Siraniko's Avatar
RX for fun
Thanks,
Brian
My reply is in the 1st gen section.
Old Jan 28, 2005 | 11:30 PM
xrotaryguy's Avatar
Im not sure I understand why a 929 pedal cluster would fit? I have a 80 Rx7 cluster. I would think that that would be closer. And you are correct about the 81 and later trannies not fitting as well. the shift levr is further back on those. thats how my 79 is. it has had the shifter hole moved back (hacked open)
Old Jan 29, 2005 | 12:24 AM
rxtasy3's Avatar
...thats how my 79 is. it has had the shifter hole moved back (hacked open)
the 79-80 trannys have the shifter in the right position for the early rotary cars. i did the mod to an 83 tranny to use in my rx3.
Old Jan 29, 2005 | 02:55 AM
Jeff20B's Avatar
Lapping = Fapping
I installed a '79 tranny in my REPU. It was weak so I threw in a '76 5 speed. Much better.
Old Jan 29, 2005 | 04:57 PM
rxtasy3's Avatar
yeah the early ribcase trannys r much stronger.
Old Feb 1, 2005 | 09:25 AM
xrotaryguy's Avatar
Hmmm Maybe I should just source everything that I need from a junk yard or find a dinosaur parts car.
Old Feb 1, 2005 | 09:34 AM
Siraniko's Avatar
RX for fun
Old Feb 1, 2005 | 10:55 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I got a set of pedals from a mid '80s 626 that I was gonna use when I converted my '74 RX4 to manual transmission. They will work with just a little modification. (The bolt that goes through them is smaller than the RX4, so to do it right you need to drill out the holes on the pedals and use a larger bolt) Anyway, I ended up finding a pedal set from an RX4 wagon in a junkyard for $10 so I ended up not needing them. The ribcase trannies are stronger, but have weak synchros so it's kind of a trade-off there.
Old Feb 1, 2005 | 11:42 AM
mortenf's Avatar
506 RWHP 12A..
The reason a 929 cluster would fit, is that the 929 is the same as the RX4, and uses a lot of the same parts, except for the engine of course... But i think you guys over the pond call the 929 the Luce or something. Magnus is from Sweden so he calls it 929. You guys didnt start to call it 929 before 87 or so, while we have called it the 929 since the 70`s!
If you have a look where the cluster should be, you should find "precuts" of where you would have to mount the pedals
Old Feb 1, 2005 | 11:18 PM
xrotaryguy's Avatar
oic. hmmm Im not sure what the 929 was then. But you guys think that the 80 Rx7 cluster is abad idea then?
Old Feb 1, 2005 | 11:19 PM
xrotaryguy's Avatar
oic. hmmm Im not sure what the 929 was then. But you guys think that the 80 Rx7 cluster is abad idea then? I amtrying to just stick to what i have in my back yard but if you all think its a better idea to go to the junk yard then I can do that. i know where theres some Rx4's. Proly charge me $50 for the set though
chiefmg
Sep 10, 2015 07:46 AM
