Power FC new mods installed, now car doesnt idle right
Old Jan 15, 2005 | 06:05 PM
buzzer's Avatar
hey guys, i just finished installing a blitz FMIC, greddy profec spec S, nippondenso supra fuel pump, and 1300cc injectors(in the stock fuel rail) so my current mods are:
Apexi power FC
dp, resonated mp, hks carbon ti
intake
blitz fmic
profec spec s
1300cc injectors
simplified sequential vacuum hose job
i tried starting my car for the first time after the install yesterday and it wasnt pretty. i am on the base map on the power fc (for now) but i was told it should at least idle fine. the car was bouncing up and down rapidly around 600-900 rpm and sounded like complete crap. there was also A LOT of smoke coming out the exhaust nonstop. any ideas what could be wrong?
thanks,
Craig
Old Jan 15, 2005 | 06:28 PM
jsplit's Avatar
How long did you let it run like this? I know the Power FC does some funky stuff in its learning phases.
Old Jan 15, 2005 | 07:02 PM
KaiFD3S's Avatar
SINFUL7
did you set the PFC for the 1300cc inj's...
Old Jan 15, 2005 | 07:10 PM
buzzer's Avatar
how do i set it for 1300cc injectors, can this be done with only the comander, cause i dont have datalogic?
Old Jan 15, 2005 | 07:13 PM
jeremyb's Avatar
Hi....
i think you require the datalogit for 1600cc injectors though I'm not sure. So I think you may be able to set the inj. for 1300cc on the commander.
Old Jan 15, 2005 | 07:20 PM
KaiFD3S's Avatar
SINFUL7
I dont have the instructions on me but you should be able to set it with the comander in the settings..
Old Jan 15, 2005 | 07:28 PM
buzzer's Avatar
ok, i have the commander instruction manual in front of me, it shows the injector data screen:
_________________________
Injector Data
Fr-Pr 100% +0.00ms
Fr-Sc +0.00ms
Rr-Pr 100% +0.00ms
Rr-Sc +0.00ms
Q-pr 550cc
Q-Sc 850cc
Fr-Pr=front primary
Fr-Sc=front secondary
Rr-Pr=rear primary
Rr-Sc=rear secondary
the percent is injector pulse correction value
and the ms are the injector lag time correction value
which ones do i change what to what do i change them?
thanks,
Craig
Old Jan 15, 2005 | 08:15 PM
KaiFD3S's Avatar
SINFUL7
go to settings
go to inj
Q-SC change with cursor to 1300cc
Old Jan 15, 2005 | 08:36 PM
buzzer's Avatar
ok did a search and found the lag times for 1300cc injectors which are +0.16ms sais jason from rx7store, i just went outside and changed the the lag time and Q-sc to 1300cc and started the car, same thing happened. you think maybe it could be something mechanical? like the injectors themselves are leaking?
Old Jan 15, 2005 | 10:19 PM
Xcessive's Avatar
Most of the time when we get a car doing what you explained, the injectors are leaking
in the holders. Reseal and you should be good to go. It should idle just like it did
before because you didnt replace the 850s and the 1300s dont work at idle.
Old Jan 15, 2005 | 10:38 PM
Jason's Avatar
The one
Make sure your map sensor is hooked up.
Jason
Old Jan 15, 2005 | 11:23 PM
buzzer's Avatar
the map sensor was the first thing i checked. the 1300cc injectors came with extra set of pintle cap things and o-rings, should i take out the injectors and replace both those things? when i installed them i put some oil on so they would go in easier, but they didnt go down all the way in the rail, i had to screw the cap thing that goes over the injectors to get them to settle down in the rail. is that how they are supposed to go? or should the injector settle down from me just pushing it in there?
Old Jan 16, 2005 | 09:02 AM
twokrx7's Avatar
Need more sleep
You may not believe this but once when I had a set of injectors cleaned they were shipped back with the test caps and o-rings on them. I knew they looked different but it was strange. They almost looked like a pintle cap but all that was needed to make them drop in was to remove the test cap and test oring.
Old Jan 16, 2005 | 07:12 PM
buzzer's Avatar
well heres a pic of the injectors i got, everyone on the forum said they are ready to drop in
Old Jan 20, 2005 | 09:08 PM
cloead's Avatar
sold--no longer in debt
Yeah.. they look exactly like my 1300s.
And they work great!
Kyo
Apr 13, 2019 09:24 AM
sYnth.
Aug 17, 2015 07:28 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
