New oil cooler & S.S.hoses
Old Dec 11, 2001 | 07:40 PM
MarkPerez's Avatar
Tennis, anyone
Well I bought a new oil cooler and stainless steel hoses . because my 7
just started leaking like crazy,,,is there anything hidden in this job i
should know before i start ????
Old Dec 11, 2001 | 09:06 PM
rxseven's Avatar
Special Dark
Don't go above torque specification when tightening fittings.
Old Dec 12, 2001 | 03:20 AM
Fire85GSLSE's Avatar
Chad Carson
Re: New oil cooler & S.S.hoses
Do not over tighten and replace the crush coper washers.
BTW did you buy a New or used?
Old Dec 12, 2001 | 09:06 AM
MarkPerez's Avatar
Tennis, anyone
I bought brand spank'n new,,The hose's were $ 101.00 and the cooler
was ,,,get this,,,$634.70 ,,both from mazdatrix,,,,Too much money,
i know, but i'll NEVER have to worry about that part of the engine..
i could have bought a used cooler for $ 100.00 but who knows the
condition it's in,,,i plan on relocateing the cooler from under the rad.
the somewhere else ,,not sure yet where,,so i'll need longer hoses..
When it comes to my 7..moneys no object,,,it's a good car and deserves
the best,,,,to a point
Old Dec 12, 2001 | 11:17 AM
Siraniko's Avatar
RX for fun
use liquid teflon to seal the fittings. 84-85 rx have mounts in front of the radiator just like the gsl-se which will allow u to use the gsl-se oil cooler. for pre-84, u have to fabricate a bracket as u dont have this option.
Old Dec 12, 2001 | 12:40 PM
MarkPerez's Avatar
Tennis, anyone
Yeah,,i understand,,and it's no problem to create mounts to locate the
cooler anywhere.I just don't like it under the rad. so close to the ground.
Even more now, $634.70 dollors for a small,but important part..****,,,
that's a paint job,,or even half a rebuilt for a 12a,,,,you know ?
Old Dec 12, 2001 | 01:35 PM
brownmound's Avatar
Anytime baby!
before you fix
It is a common fix for the 84-85 leaky oil cooler to simply remove it and take it a guy who can do aluminum welding. I took mine off, took it to Steve the welder. He was completely familiar with the problem "It's a SH*TY F*ING design, Mazda really F*ED that one up." (He talks really, really loud-welder.) He had fixed several before. He charged me $70 and welded the hell out of the fitting outlets, grinded em flush. Got new crush washers and SS hose, no leaky now.
So, maybe consider this as an option if only your fittings are leaking, and see if you can return the oil cooler to Mazdatrix. Good luck.
Right on-
Old Dec 13, 2001 | 11:20 AM
Chad Carson
See if you can return the cooler. My friend is the parts manager here at Mazda and can get me a new cooler for under 400.00.
Let me know if you want me to get this for you.
Chad
Old Dec 13, 2001 | 12:16 PM
MarkPerez's Avatar
Tennis, anyone
I've already installed everything,and for now it's under the rad.did it last
night,,,easy job to do too,,engine temp. is lower and oil presure is a bit
higher at 70 mph and at idle...thanks anyway guys and i'll remember
your info for the future and others to come to the forum mark
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
