Wastegate porting question
Old Dec 30, 2004 | 06:38 AM
BGH's Avatar
BGH
I just finished porting my wastegate my question is.
Is it possible to install a bigger flapper in place of the stock
one, if so where can I get one.
Old Dec 30, 2004 | 06:42 AM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
search there are a million threads on this.. the president speaks
NZConvertible's Avatar
I'm a boost creep...
If you don't install a bigger flap you're basically wasting your time.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/serious-s4-wastegate-porting%85-343788/
Old Dec 30, 2004 | 06:45 AM
BGH's Avatar
BGH
NZ did you jb weld the washer on or
did you spot weld it?
Old Dec 30, 2004 | 06:54 AM
BlaCkPlaGUE's Avatar
I live in an igloo
I think he mentioned either in that post or somewhere else that he spot welded it. Would jb weld hold up with all that turbulance and heat?
Old Dec 30, 2004 | 07:03 AM
BGH's Avatar
BGH
I am not sure if jb weld would hold up,
I seriously dont think it would work.
I guess thats my answer.
I was just wanting to verify if
you could by a aftermarket flapper
that would work.
Old Dec 30, 2004 | 07:18 AM
BGH's Avatar
BGH
The great thing about the forum
is you ussaly wind up anwering
your own questions after your
reminded of the obvious.
Old Dec 30, 2004 | 07:56 AM
TwistedRotors's Avatar
Compression Tester Guy
I welded a stainless steel washer onto the face of the stock flapper.
-John
Old Dec 30, 2004 | 05:19 PM
JB Weld wouldn't last 60 seconds!
The washer was TIG-welded onto the flap. It's a continuous bead, not a spot weld.
Skeese
65
Mar 28, 2017 03:30 PM
Engine stand ready
Aug 14, 2015 10:26 PM
